99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
Old 03-21-2016, 12:31 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota Tundra Brake Guides
Print Wikipost
Brake line fittings
Old 05-10-2014, 08:47 AM
Amnesiac's Avatar
Brake line fittings
Hi all,
I just did the caliper upgrade for my 2001 tundra and during the process, I had to replace one of the brake lines, the metal one that screws into the caliper. I bought an 8" line, 3/16" diameter (4.7mm x 20.3 cm) from Oreillys and all it says is that it has metric threads. Are these fittings just a generic metric thread?
I installed the line and the brakes work, but the fittings seem to be slowly leaking brake fluid.
Thanks
Old 05-10-2014, 09:57 AM
Staff
DeathCougar's Avatar
Depth of the fitting could be an issue. If it doesn't hold the line tight in there it will simply leak.
Why not just go to the dealer, they are pretty cheap and you are getting a prebent one that you know fits right the first time.
Old 05-10-2014, 10:00 AM
Amnesiac's Avatar
I didn't realize the dealer sold pre-bent lines. I'll check it out, thanks.
09-04-2015 09:27 AM
CanRunner
07-20-2015 01:29 PM
rondogracing
07-14-2015 07:00 PM
87turboPA
07-12-2015 07:49 AM
87turboPA
07-09-2015 05:58 AM
Quick Reply: Brake line fittings
