| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
2000 Tundra - Heater problems
#2 (permalink) | |
Quote:
Might have a clogged or bad heater core if cold air is just coming out.... |
#3 (permalink) | |
Quote:
#4 (permalink) | |
Quote:
#5 (permalink) |
Yes, the flow is barely warm. I thought about the clog possibility, but the fluid I drained when replacing the thermostat (180 degree) was very clean.
#6 (permalink) | |
Quote:
Family members Matrix A/C was not cool enough and it was just a cable adjustment. |
#7 (permalink) |
The cable for the temp control? I can hear the vent change, but perhaps it's not moving far enough.
#8 (permalink) | |
Quote:
__________________
'01 Tundra Limited TRD 4x4: TRD exhaust, IS Grill, 265/75 Yokohama's, AR-23 Rims, Red Hellwig Sway Bar, SnugTop XV, BedRug, Yakima Rack. Waiting to be installed: HD TRD Bilsteins '87 4Runner SR5 |
#9 (permalink) | |
Quote:
Did you check the heater valve? Does it move when you turn the temp. control dial? Did you check the heater control assembly? It seems like many of the heat problems come from one of the control cables coming uncliped, especially behind the glovebox.
__________________
| Tags |
| hellwig, movement, tundra |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 99Runner, heater problems | uberhiker | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 01-15-2007 05:47 AM |
| heater core or valve problems? | nieveparasiempre | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 12-02-2006 08:27 PM |
| heater problems | john c | Early Land Cruisers | 9 | 12-08-2005 01:27 PM |
| Heater control problems | OneTrickToy | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 03-06-2004 10:18 PM |
| 2000 Tundra needs help | johnnyv5 | 99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 | 8 | 11-25-2002 09:00 AM |
