YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Early Land Cruisers
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 12-18-2007, 12:58 PM   #1 (permalink)
Spring over
Whats is all needed to do a spring over on a 62 series Cruiser? Also with the spring over willl I be able to fit 35's? Thanks in advance.
__________________
1994 Toyota 4x4 22re
premirrider is offline
Sponsored Links
To remove this ad, register today!
Old 12-29-2007, 12:29 PM   #2 (permalink)
35s should fit fine. There is a ton of info on this at Ih8mud You may be able to run 37s pretty easily.
ffx60 is offline
Old 12-29-2007, 12:41 PM   #3 (permalink)
fillsrunner4's Avatar
Send a message via AIM to fillsrunner4
New pearches. you could get some from Marlin or even some local shops should have some. Probaly new shocks too
__________________
94' toyota 4runner (Many a change!) purchased bone stock, NOW... SAS, 37x14" Iroks, Rear Leafs, 5.29's , Air locked front, Welded rear, 4.3L, Chevy V6 , 5spd swapped, dual T/C's MC10R10, flatbelly with custom skids, sliders, and so much more.
Might as well start reading this if ya want know more
Fillsrunner4 3.4crawler Build Thread
Fillsrunner4.3 crawler (Part Two) build thread
fillsrunner4 is offline
Old 12-29-2007, 01:02 PM   #4 (permalink)
The big part is cutting and turning the front axle. Perches, longer brake lines, some do a shackle reversal, I believe most need to swap out the front driveshaft as well. High steer kit too.
ffx60 is offline
Old 12-29-2007, 01:03 PM   #5 (permalink)
Depending on how much life you have in your stock springs, you may need to add a leaf as well
ffx60 is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Spring help blu82project Pre 84 Trucks 0 08-17-2007 03:41 PM
CB Antennae: Spring or No Spring Demosthine GPS & Communication 11 08-26-2005 10:06 AM
Spring over axle? Tacoma750 95.5-2004 Tacomas & 96-2002 4Runners 3 01-17-2005 10:39 AM
Spring Help 98_YOTA 95.5-2004 Tacomas & 96-2002 4Runners 0 12-03-2004 02:41 PM
Spring Cleaning Help? Herd72 95.5-2004 Tacomas & 96-2002 4Runners 4 03-19-2004 03:01 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
