YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Early Land Cruisers
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 02-24-2007, 06:33 PM   #1 (permalink)
sourcing diff drain/filler plugs for BJ42 1983 - not 24mm, not imperial??
I am finding that the diff drain bolts and filler plug bolts are not really exactly 24mm - that size fits but tends to roll over - the 7/8 does not fit at all.
I have also heard that these plug bolts are tapered and do not require washers which may be why they have ended up super tight and one of them totally unremovable - going to have to plug weld it I think since I have mangled the filler plug for the rear.
Super Cheap don't seem to know what the story is.
Can anyone positively id these drain and filler bolts for me?
I would like to source new ones for both diffs if they are available...
Will
stardotstar is offline
Sponsored Links
To remove this ad, register today!
Old 03-25-2007, 07:51 PM   #2 (permalink)
JGM
JGM's Avatar
Try specter offroad....sor.com
__________________
1996 4Runner & 1971 FJ40
JGM is offline
Old 03-26-2007, 03:04 AM   #3 (permalink)
thanks for that !! awesome link
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Service/Tech Manual for a BJ42 LX 1983? stardotstar Newbie Tech Section 0 02-10-2007 01:41 AM
part #s for rear diff. and transfer case filler plugs swerks 86-95 Trucks & 4Runners 0 10-23-2006 03:38 PM
Tacoma Coolant Drain Plugs Timber03 Maintenance & Repair Archives 3 01-22-2005 01:35 AM
Washer size for 24mm fill and drain bolts GodwinAustin 95.5-2004 Tacomas & 96-2002 4Runners 9 12-16-2004 06:18 PM
Where's the block drain plugs? PY Maintenance & Repair Archives 1 08-11-2004 08:29 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
