Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
glow plugs
want to replace my glow plugs on 83 landcruiser bj60 3b motor. have no clue where to start. any help.
| Sponsored Links |
#2 (permalink) |
Check them with an ohm meter first. I'm not sure what the value should be for your rig, but an open circuit = bad glow plug. Put one lead on the terminal of the GP and the other should be grounded to the block.
#3 (permalink) |
replacing them today. is it as easy as unscrewing the old ones and screwing the new ones in? do i need to prime the cylinders? thanks
#4 (permalink) |
First off do you know what the function of glow plugs is? All they do is heat up the air in the cylinder or head when you first turn your key before you engage the starter. After that they are not used. The only reason you would need to replace them is if they no longer work and you live in a cold climate where they're needed to get it started. As to replacing them if you really do need to they probably have an o-ring so that the high compression will not escape past them and im sure there is a torque, look for an online fsm for your truck or motor.
__________________
85 reg cab s/b, rebuilt 22r, .040 over bore, engnbldr's crawler cam, no cat w/ flo-pro (was on it). tg 5 inch lift. 35 baja claws bright green paint, sliders, custom front bumper, miller rear locker --project-- 02 dodge extended cab s/b, black sport, 24 vavle cummins, 35's, 4 inch exhaust, edge ez |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| iridium plugs and regular plugs for 2002 3.4 liter | mkgarrison5 | 95.5-2004 Tacomas & 96-2002 4Runners | 18 | 02-07-2007 09:35 AM |
| 96-98 Reverse Glow Gauges | 98runn'n | Misc Stuff (Vehicle Related) | 1 | 02-22-2006 11:23 AM |
| Glow needles? | JEDI87 | 95.5-2004 Tacomas & 96-2002 4Runners | 17 | 12-11-2004 05:52 AM |
| Rare glow gauges | bike4miles | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 05-24-2004 09:37 AM |
| HELP!!! reverse glow gauges!! | dexter | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 09-25-2003 02:00 PM |
