YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Early Land Cruisers
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 09-08-2006, 11:26 AM   #1 (permalink)
Symon623's Avatar
Send a message via AIM to Symon623 Send a message via MSN to Symon623 Send a message via Yahoo to Symon623
FJ/FZJ80 rear axle Q's
A friend of mine has a 92 FJ80 with drum rear brakes, would like to convert to rear disc. What is needed, besides the axle and a mastercylinder swap, will it take to swap in a FZJ80 rear axle? I know the track width is about a inch wider, But will the suspension line up? Driveline mods? Change to 16" or bigger wheels?
Any and all suggestions are appreciated.
Thanks
__________________
Sy
85 Syota - 4.3/700r4/300/60's/§XX§
High Country Renegades/ARC
Symon623 is offline
Sponsored Links
To remove this ad, register today!
Old 09-09-2006, 10:51 AM   #2 (permalink)
firemedic's Avatar
Not sure on the other stuff, but you will have to move up to 16" wheels or grind the calipers (I wouldn't) to fit 15" wheels. I believe driveshaft should still fit, as well as suspension.
__________________
Ben Silva
96 Lexus LX450, 125k, front/rear OEM diff locks, CDL switch, Pin 7 mod, power points, wired 850w inverter, jdm "oh crap" bar, OME heavy (850/863) lift, 285/75/16 Cooper STT, spare tire lift mod
98 Lexus LX470, 135k, Britax car seat ;)
TLCA member #14300
Camas, WA USA
firemedic is offline
Old 09-09-2006, 11:10 AM   #3 (permalink)
Sponsoring Member
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
www.ih8mud.com
waskillywabbit is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Rear Axle Q's CTRJ 95.5-2004 Tacomas & 96-2002 4Runners 1 01-10-2007 04:59 PM
1997 FZJ80 Low Pinion eLocker Diff or Rear Axle Discyota Axles/Suspensions/Tires/Wheels 1 10-11-2006 07:58 PM
1997 FZJ80 Land Cruiser Rear eLocker Axle Discyota Axles/Suspensions/Tires/Wheels 0 09-05-2006 09:52 AM
Taco TRD axle q's....ASAP Yoda 95.5-2004 Tacomas & 96-2002 4Runners 2 07-11-2006 04:09 PM
88 axle-swap tranny seat q's greyman 271 95.5-2004 Tacomas & 96-2002 4Runners 6 02-15-2003 03:20 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
