YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Early Land Cruisers
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 12-28-2007, 11:22 AM   #1 (permalink)
Electrical Problem?
My friend was driving my 60 the other day and had a problem when reversing into a parking space. Pretty much as he describes it this is what happened:
He backed in, then went forward so he could back in again and straighten out. As he was backing in the second time the engine stalled, but apparently it was a real clean cut and at first he wasn't even sure it had. Then the steering column started smoking.
He took the keys out and left it parked. We haven't tried to start it again because obviously we don't want it to get worse. Any ideas what it might be and what it would take to fix it would be appreciated.
Thanks
jakesooy is offline
Sponsored Links
To remove this ad, register today!
Old 12-28-2007, 11:45 AM   #2 (permalink)
notanymore's Avatar
a short on the ignition system that is in the steering column would be my first guess
__________________
my truck: 1987 pickup xtra cab sr5 22re 5 speed 4wd, 31x10.5's eb 261c cam, lce header, 2.25 exhaust.
other ride: 1980 Honda CX500-
notanymore is offline
Old 12-28-2007, 11:48 AM   #3 (permalink)
do you think its adviseable to try and start it again?
jakesooy is offline
Old 12-28-2007, 06:16 PM   #4 (permalink)
So, as an update. I tried to start it and got nothing. No response from the starter or from anything really when I put my key in. I looked around and a red wire leading through the steering column past the blue piece on the wiring harness was melted. Tried to take my column apart to look at what it connects to but it had a stripped screw.
Any advice on what needs replacing, besides the wire of course.
Thanks
jakesooy is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
A/C Electrical Problem Jonnym General Electrical & Lighting Related Topics 2 10-02-2006 05:57 AM
Help with electrical problem montanatoy 86-95 Trucks & 4Runners 1 08-10-2006 04:23 PM
electrical problem toyotadreamz Maintenance & Repair Archives 3 08-09-2005 04:52 PM
Electrical problem van7559 95.5-2004 Tacomas & 96-2002 4Runners 3 12-08-2004 12:32 PM
Electrical Problem Help RkyMtn_Toy 95.5-2004 Tacomas & 96-2002 4Runners 3 02-27-2004 08:50 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
