YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Early Land Cruisers
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 10-02-2006, 04:01 PM   #1 (permalink)
peacekeeper1961's Avatar
Check Engine Light 1997 FJ80
I have a 1997 Land Cruiser, TRD Supercharged, with 107, 000 miles on the clock. A couple of years ago, prior to adding the Supercharger, the check engine light would come on occassionally. It was setting O2 senor codes so I replaced both sensors with new OEMs. The light stayed off up until a couple of weeks ago now the light is on and it is setting sensor codes again. I have noticed zero drivablity problems. Can anyone advise if they have had this difficulty as well? By the way, I am also running a Borla exhaust. Thanks.
peacekeeper1961 is offline
Sponsored Links
To remove this ad, register today!
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Engine swap/check engine light? spacoli 86-95 Trucks & 4Runners 1 11-29-2006 07:39 PM
1997 FJ80: Is it worth it? rwmorrisonjr Off Topic Talk 11 02-17-2006 09:00 AM
Engine Miss/Check engine light - Possibly TPS? Extremesolo 95.5-2004 Tacomas & 96-2002 4Runners 2 09-17-2005 09:58 PM
check engine light + engine miss descendents 95.5-2004 Tacomas & 96-2002 4Runners 6 11-03-2003 07:51 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
