Automatic vs manual gear box
Hello every one
I have a fzj80L gnpeka with
- a442f automatic gear box
- 4.55 deffrential ratio (standard tier size 275/70 R 16 ) which I modified original is 4.11 ratio
- part time conversion with dash switch installed
- front weel hubs
I have problems with the automatic gear box so I thought of shifting to manual gear H151F 5 speed.
My concern is the 5th gear ratio in the manual is 0.881 :1 which I think will reduce the car general speed even more than what it is after my reduction from 4.11 to 4.55 deffrential ratio
In the A442F the 4th gear ratio is 1:0.756
Has any one done this shift to manual and faced this problem of general speed reduction
Thanks a lot
- front weel hubs
Thanks a lot
The combination of going from 4.11 to 4.56 gears and changing the transmission ratio from 1:756 to 1:881 will give you a 29% change in your top gearing. If, for example, before you were running 3000 rpm at 70mph, after the two changes it would require 3870 rpm for the same speed. That's a pretty big change, and you're right to be thinking twice about it. Maybe change to bigger tires at the same time to better match the new gearing.
Ron
Ron
BeMiceElf
10-10-2015 09:40 PM
rushw
07-18-2015 01:46 PM
Seattle_Sign_Guy
07-12-2015 12:38 PM
Poncho0206
07-10-2015 06:21 PM
