88' FJ62 Power Window HELP!!!
So I recently purchased my 1988 FJ62 from its original owner. To say the least im stoked to finally have one! Anyway, i'm having trouble with the power windows. I have researched some have have read both threads by "slcfj62" on Ih8MUD.com and did replace the realys in the little green box, and have taken apart the master switch and polished the points up, making sure to install the rockers correctly, and still no luck. So the symptoms/issues im having are weird. Starting with the drivers door/master control switch/window lock on, I can roll the drivers window down/up with no issues. If I turn the lock switch off, I can roll it down, but have to use the passenger rear switch to roll it back up. Keep in mind i'm still using all the switches on the master switch. So onto the drivers rear, rolls up and down without any issues using the master switch and the door switch. Moving over to the passenger side, when I activate the front passenger window switch I get nothing but a "click" out of the door motor. If I turn the lock switch on, I get a click in the door motor and the relay box in the drivers door, both showing that its pulling power in the volt meter. Onto the passenger rear, I get the same results and passenger front. So after fighting this for a week now Im hoping someone has a solution!! As I said, relays in the green box have been replaced and the symptoms were the same before I replaced them. If anybody has any advice please share. Thanks
06-01-2021 01:51 PM
FS[PacNorWest]: 1987 Toyota 4Runner $1800 Whidbey Island, WA
coreyedwards7611
01-16-2016 06:38 PM
Johntom240
7
07-13-2015 12:18 AM
