YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Early Land Cruisers
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 09-05-2006, 06:25 AM   #1 (permalink)
BLU CIVIC's Avatar
1994 Landcruiser brake problem
Ok, here the problem. My brakes needed to be changed. the brake pas in the rear had started rubbing into the rotor. so i ordered brake pads for the front and rear and rotors for the back. changed the brake pads on the front (even though they didn't need to be changed), changed the passenger side rear rotor and brake pads and started to change the drivers side rear rotor and brakes when i found something odd. the inner brake pad had fallen off (don't know how) and the caliper piston was grinding into the rotor. on the brake pad there was like no brake, just the pad.the it's odd because there was nothing wrong with any of the other brake pads just this side. can anyone give me some advise on how this could have happened and wh4ere i can get another caliper piston.
BLU CIVIC is offline
Sponsored Links
To remove this ad, register today!
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
1994 Landcruiser Mass air flow sensor/meter 4ROMPER Axles/Suspensions/Tires/Wheels 1 07-09-2006 03:46 AM
IFS Caliper and Landcruiser Brake upgrade WVpizzaguy 84-85 Trucks & 4Runners 6 03-08-2006 10:56 AM
95 Landcruiser brake problems. Help coloradosafaris 95.5-2004 Tacomas & 96-2002 4Runners 3 07-17-2005 10:42 PM
2001 Landcruiser idle problem virafp Early Land Cruisers 1 10-31-2004 04:42 PM
Brake light on 1994 Runner ???? RUNNING BOARD 95.5-2004 Tacomas & 96-2002 4Runners 5 07-02-2004 02:25 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
