PowerTrax No-Slip Clearance - Just Differentials
Looking for a deal on a locking differential? We have overstock PowerTrax No-Slip units at the moment and are looking to move them out. Check out the link below, call 866-349-6801 or email info@justdifferentials.com to verify availability.
The POWERTRAX® TRACTION SYSTEMS are the latest design in traction adding differential technology. It combines the smooth operation of a limited-slip differential, with the traction performance of a locking differential. A precise synchronization mechanism eliminates the ratcheting sounds typical of other locking differentials. Special gear and spring design reduce the backlash and therefore driveline windup. Only ultra strength material is used which is 67% stronger than titanium.
Installation is simple because no ring and pinion set-up is required. In addition, no special tools or oils are needed. Step by step model specific instructions are provided with every kit.
The POWERTRAX® TRACTION SYSTEMS are the ideal solution for just about any light truck, sport utility, and muscle car on the road today. Whether you need the safety of added traction for daily commuting, recreation, work, or just so your muscle car puts power to the pavement instead of buring one wheel up, the POWERTRAX® TRACTION SYSTEMS are your answer.
Bumping this back up! These deals are only available until we are out of stock of these lockers. If you have questions about availability you can check online, email us (info@justdifferentials.com) or call us (866 349 6801) and we can see if there is a PowerTrax No-Slip in stock for your axle!
kawazx636
10-06-2021 03:03 PM
scott90
10-04-2015 09:21 AM
Odin
09-26-2015 06:56 PM
