Toyota Rear Full Floating Axle Flanges!
Old 03-23-2012, 01:07 PM
  #41
FormerVendor
Gravel Maker's Avatar
Now available in 3.5", 3.25", & 3" ID so you can add them to just about any axle tube size...
Old 04-01-2012, 09:26 AM
  #42
ATVTRAILRIDER's Avatar
Ok, i am interested in ordering up an axle with a set of these flanges on it. Now how do i figure out the width i need and the length of the custom axles to order?
I need a wheel mounting surface of 65 inches to mtach up with my total chaos front end. I have some extra ifs spindles and calipers.
Old 04-03-2012, 08:43 AM
  #43
FormerVendor
Give us a call to work out the particulars...
Old 04-30-2012, 03:22 PM
  #44
FormerVendor
These are very popular, almost time to make our 3rd batch!
Old 04-30-2012, 05:22 PM
  #45
RMA
RMA's Avatar
so using these flanges makes the axle narrower ?
what seal are you using to keep the oil in ?
thanks !
Old 05-01-2012, 12:15 PM
  #46
FormerVendor
thanks !
Using these would make the axle longer if you took your flanges off at the very end. You can decide how long to make it. Over half of these have been used on custom housings like ours, TG's, or Diamonds... You would use the spindle seal or an internal seal like a Sealsit seal.
Old 06-05-2012, 02:47 PM
  #47
FormerVendor
Smile Toyota Rear Full Floating Axle Flanges!
WELD ON SOME BEEF
Old 06-11-2012, 01:08 PM
  #48
FormerVendor
Thumbs up Toyota Rear Full Floating Axle Flanges!
WELD ON PERFORMANCE
Old 08-24-2012, 10:38 AM
  #49
FormerVendor
Arrow Toyota Rear Full Floating Axle Flanges!
The best way to turn your semi float into full float !!
Old 09-11-2012, 10:49 AM
  #50
FormerVendor
The best way to upgrade your semi float into a full float axle !!
Old 10-29-2012, 06:36 AM
  #51
FormerVendor
Always a great choice!
Old 12-10-2012, 06:56 AM
  #52
FormerVendor
Thanks for all of the orders guys!
Old 02-08-2013, 07:37 AM
  #53
irab88's Avatar
hey, just another quick question: did you ever find out what axle shafts to use?
Old 02-08-2013, 07:49 AM
  #54
RBX
RBX's Avatar
Thanks for reminding me Ian, I also need this info as i am about to pull the trigger on a set of these flanges.
Also another question, I read in another post that RuffStuff was also going to make a 'bolt-on' set of these adapters...any word on that? I can weld, but i am not going to attempt to see if i can weld these adapters on straight.
Old 02-14-2013, 02:44 AM
  #55
RBX
RBX's Avatar
Any word ?...bump for an awesome sale right now.
Old 02-14-2013, 10:39 AM
  #56
FormerVendor
Give us a call bud, we'll get you taken care of!
Old 02-14-2013, 11:04 AM
  #57
RBX
RBX's Avatar
I called and as usual the staff is always very helpful and courteous. I have to wait until tomorrow when i get paid to make the purchase.
Thanks Dan for the great products, it really helps guys like myself that have to build in phases or acquire parts as $$ is available.
Also, the gentlemen on the phone told me the name of the company that you get your axle shafts from for this swap, do you mind me posting it here, since i know this is a big question to some folks like myself.
Old 02-15-2013, 08:11 AM
  #58
RBX
RBX's Avatar
Ordered using the valentines discount. Thanks!
Old 02-15-2013, 09:47 AM
  #59
FormerVendor
Thank you for the order! Glad we could help!
Old 04-22-2013, 12:17 PM
  #60
FormerVendor
The toyota full floating flange isn't just a luxury, it's a must have!
Quick Reply: Toyota Rear Full Floating Axle Flanges!
