Toyota Rear Full Floating Axle Flanges!
Old 01-03-2012, 05:17 AM
RBX
RBX's Avatar
Cool,
Lets see some install pics, and if you could include some part numbers that you are using to complete the axle build i would greatly appreciate it.
thanks
Old 01-04-2012, 11:26 AM
FormerVendor
Gravel Maker's Avatar
Originally Posted by RBX
Cool,
thanks
We will!
Old 01-12-2012, 02:37 PM
FormerVendor
I am sorry but we haven't yet had the time to do mine, maybe tonite!
Old 01-13-2012, 07:32 AM
RBX
RBX's Avatar
Bump...
Just got my spindles yesterdee from a fellow yotatecher, and have a line on freshly rebuilt SFA hubs for 70 beans.
bearings, shafts and these fine flanges are on the list.
Old 01-13-2012, 07:56 AM
  #25
irab88's Avatar
i am subscribing
(doing the same thing rb is)
Old 01-19-2012, 03:48 PM
  #26
FormerVendor
Here are some pics installed, they are on one of our 9" housings I am using in the rear of my FJ45 pickup...
Just the flange...
With the spindle...
With the Hub, Rotor, & Caliper...
Its really a pretty simple operation and this is just about all the instructions anyone will need. Of course I am running 31 to 30 spline shafts but they are damned easy...
Old 01-19-2012, 04:36 PM
  #27
irab88's Avatar
that looks good. really good.
if you happen to know, what's the difference in width between that axle and a yota 8"? or if you know the width of that one, i can measure mine (just curious about axle lengths/types to use)
Old 01-19-2012, 05:05 PM
  #28
RMA
RMA's Avatar
looks great !!.. so the calipers are IFS S12,S13, the rotors are fj40 or fj60.....and what are the spindles from ?
Edit : never mind i went back to your first post..
This is a weld on Axle Flange to mount Front Toyota Mini, Fj40, or FJ60 spindles to the rear axle. The caliper bosses are made to use the IFS Truck ('86-'95) calipers and FJ40 or FJ60 rotors.
so do you know if any stock axles can be used to keep the FJ40 width,using your axle housing with an fj40 diff?
Old 01-19-2012, 08:48 PM
  #29
FormerVendor
This one is FJ80 width, a shave under 64, I believe it was 63.75".
There are alot of different front inner axles you could use but I think the 80 or 60 may be the only long enough for an offset housing. For a centered housing anything from an FJ40 on up should do it if you cut and respline one end. One of my employees is getting ready to do this to his and we have a ton of inner axles around so we will see what can be done with stock stuff then.
Old 01-19-2012, 08:55 PM
  #30
FormerVendor
We made a couple of discoveries on this one. One caliper was from an early axle and the other was from an FJ60 (Much heavier). Both will work with the early rotors we used here but if you have the later IFS or FJ60 calipers you can use the later vented rotors. The space between the pads is wide enough on the later stuff but either caliper will work on the early rotors.
For your question we will find out over the next few dys or weeks as we do Jay's axle...
Old 01-20-2012, 04:11 AM
  #31
irab88's Avatar
sweet, thanks
Old 01-20-2012, 06:22 AM
  #32
snobdds's Avatar
I like this a lot. I like the ease of redoing full floating axles. Once the actual lenght of the inner axle is figure out, I might have to get me a set...keep us posted.
Old 01-20-2012, 06:46 AM
  #33
RBX
RBX's Avatar
Since these are weld on flanges, what dies one do about the 4-bolt mounting area? In other words, what is the best way to center these flanges on the axle and weld to?
Old 01-20-2012, 07:01 AM
  #34
RMA
RMA's Avatar
^good question..how do you true it all up....maybe a rod all the way thru the axle..
Old 01-20-2012, 09:19 AM
  #35
FormerVendor
Arrow Some answers for you...
The axle should not really be too much of a concern. It would be great if you could use a used front inner axle but I would say build it to the length you want and don't compromise by building it to an existing part...
You would remove the 4 bolt flange, it isn't used any longer. You would be using double splined axles like front inners.
We install them using a trubar but a simple instalation trick would be to use a long (5') piece of heave DOM or 3" angle iron and 2 machinist squares. Clamp it about 3" off the faceplate and setup the correct length and then with the machinist squares true them to each other. Pretty simple...
Old 01-22-2012, 09:12 AM
  #36
FormerVendor
I thought while I was showing the rear I might as well show the front it is pairing up with!
It looks a little out of scale because those are FJ80 knuckleballs for the Hellfure Fab Knuckles and Highsteer. If I have the time to finsh it today I will post it up
Old 01-22-2012, 10:07 AM
  #37
RBX
RBX's Avatar
Very nice
Old 01-25-2012, 10:33 AM
  #38
FormerVendor
Here is the finished front axle, I did not know for sure but I am happy to report that FJ40 and Mini Aisan lockouts are a direct replacement for the fulltime factory stuff!
Old 01-27-2012, 10:20 AM
  #39
FormerVendor
We got a ton of calls about the Hellfire Knuckles and High Steer after I posted this. We are the only distributor of them besides buying direct from Billy at Hellfire. I haven't advertised them because Billy sold the entire 45 pair of the first batch in 6 weeks. The next batch should be available in a couple of weeks!
Old 03-07-2012, 08:04 PM
  #40
FormerVendor
We are putting these or the D60's on just about every other axle that goes out!
Quick Reply: Toyota Rear Full Floating Axle Flanges!
