Prerunner & All 2WD Rigs Discussions pertaining to non 4WD rigs
truck will not start
Old 03-12-2012, 10:20 AM
'79 beagle hauler's Avatar
Het guys I need some help the truck is a2000 prerunner 2.7 engine it will not start and the tail light don't work or blinkers nothing got fire to starter what should I do next.thanks
Old 03-19-2012, 09:12 PM
78yotawolverine's Avatar
Check the spark plugs. take out one of the plugs and turn it over with the lights off to see if you've got spark. if you have one of those testers that lights up when it gets current that should work too.
You probably have an electric fuel pump so check that too. If it is anything like my 78, the pump wont start unless you are turning over the motor or the truck is running. Of course I was an idiot and though my pump wasnt working so I wired it to a switch which I kind of like now.
Theres a start.
Old 03-19-2012, 09:41 PM
totally a bro
Staff
vital22re's Avatar
Can you please elaborate on what it does or doesn't do. Do you have 12 volts at the battery? Do you have spark? do you have fuel? Does the starter engage the motor and turn it over? does it turn over healthy or is it rotating slow and sluggish?
Old 02-11-2015, 08:55 AM
dscotty5fsu's Avatar
Battery bad?
sounds like a bad battery or fuse
bigblue82
10
07-06-2015 08:27 AM
Badger62811
06-26-2015 09:26 PM
slider417
06-22-2015 10:18 AM
jmc88runner
06-18-2015 03:39 PM
Quick Reply: truck will not start
