Prerunner & All 2WD Rigs Discussions pertaining to non 4WD rigs
'84 22r mileage
Old 11-21-2015, 07:10 PM
opus's Avatar
'84 22r mileage
Greetings one and all,
First post here so here it is;
'84 22r, 2wd, 327k miles. Sounds like it just came from the factory. Timing chain just done. Oil sample says its pretty nice for that many miles.
Run it til it dies??
Old 11-21-2015, 10:17 PM
Robert m's Avatar
If its not consuming oil and has good compression. Run it!
If it aint broke, don't fix it.
Old 11-22-2015, 04:38 AM
bootscootboogie's Avatar
Replace it and sell me that high mileage junk
Just kidding. Yeah run that sucker. Find a 4x4 that needs an engine, swap that bad boy over, and have fun.
Old 11-22-2015, 06:34 AM
opus's Avatar
Actually, its the only 2wd I own and I rather like it. First 2wd truck I've owned in 40 yrs.
Old 11-22-2015, 07:44 AM
Staff
Terrys87's Avatar
Sometimes I miss my little two wheel drive. You get better mileage and they will get up and run for a 4 cylinder. I put some Ford Ranger wheels on mine and swapped out the 4 speed transmission with an 83 Celica 5 speed transmission for better mileage. It is a direct fit if you are looking for some other options. You might want to look into installing a Weber carburetor if your Aisin is getting worn. Welcome to Yotatech.
Old 11-22-2015, 07:52 AM
opus's Avatar
Thanks for the welcome. I have Weber's on my Soob's. I have desmogged this Aisin as much as I could. This carb is really good. I wanted to change out but it runs too good to make the change.
Did these come with a 4 spd originally? I bought it for $200 without a transmission. I grabbed a 5 spd and stuck it in, assuming thats what came with it. Got maintenance records for it since the guy bought it new.
It scoots along nicely. Just decided to fix it up a bit for my last daughter that starts driving in a couple years, she loves it. Its a long bed with hooks. I need to make a couple of the typical panels for it, from the rot at the seams. Cab is fine.
Old 11-22-2015, 08:06 AM
Staff
Terrys87's Avatar
Some had 4 speed and some 5 speeds. My truck was a very base model and was shipped as a "Cab and Chassis truck" which basically was a work truck or for commercial use. From what I have seen those seem to be 4 speeds and I could be wrong on that.
Two wheels usually did not get all the lights, bells, and whistles. https://www.yotatech.com/forums/f123...ap-mods-62861/ Here is a few things that you can add to them that makes them a little nicer. The SR5 gauge swap is another mod really common.
Old 11-22-2015, 08:15 AM
I have a 2wd Tacoma that is my baby. It's great to have one for going to pick up parts for other projects.
gibbonsballer10
10-26-2023 07:13 AM
Obmi
01-04-2016 06:22 PM
mechagouki
12-20-2015 04:06 PM
alexcarey
10-04-2015 09:56 AM
Obmi
09-16-2015 02:13 PM
Quick Reply: '84 22r mileage
