Vendors Build-Ups (Build-Up Section) Vendors can showcase customer builds here
toyotafiberglass - Erik's runner
Old 11-22-2013, 05:21 PM
slacker's Avatar
Erik brought us his runner to repair ..
previously , some other person had cut the rust out , and made it work for a few years , but now time to do it right !
and the cuts on the outer wheel house ..
Old 11-24-2013, 02:50 PM
gillesdetrail's Avatar
Another one of your nice project I'll be following! Have fun with this one!
P.S. which gen do you like working on the most?
Old 11-25-2013, 04:14 PM
slacker's Avatar
Thanks
i'm partial to the first gen trucks ... and I love the trekkers .
4Runners are also a passion .. so I'm very lucky , I get to build em all
Old 11-25-2013, 04:29 PM
slacker's Avatar
got the old sheet metal off .. and here's why I recommend doing the whole panel instead of a patch
clearly you can see the rust !! also .. it allows you to clean and repair the complete inner .
because of the previous owners "repair" , we had to replace the outer wheel house on both sides
and with everything all cleaned and prepped , time for some POR 15
and wheel house "glued"
Old 11-26-2013, 05:08 PM
slacker's Avatar
with everything cured , the rear 1/4r panels are now fit and epoxied into place
also got the fronts on
Old 11-26-2013, 05:16 PM
HighLux's Avatar
You are truly a Master Craftsman, and a hero to Toyota restorations.
No BS. I mean it. I hope to shake your hand someday.
Old 11-26-2013, 05:17 PM
slacker's Avatar
thanks brutha ..
Old 11-27-2013, 12:16 PM
dsal_86Yota's Avatar
Your skills are incredible. Your doing great things saving old Yotas.
Old 11-27-2013, 03:38 PM
slacker's Avatar
thanks
Old 11-27-2013, 03:45 PM
slacker's Avatar
and last but not least , our new rear inner panels installed
and everything back together today ..
Erik picked up , and another happy customer
Old 02-18-2014, 06:22 PM
slacker's Avatar
well Erik is back ..
Dropped us a deposit for a 3.4L install ...
coming soon
Old 02-18-2014, 06:27 PM
BigBluePile's Avatar
I didn't see it but is there a weight savings? Just curious great stuff!
Old 02-18-2014, 06:32 PM
slacker's Avatar
no .. our panels are built for strength , not weight savings .. if you want this "special option" we can do it , just not a "production " piece ..
Old 03-09-2014, 07:34 PM
slacker's Avatar
Erik just dropped us a deposit for the 3.4L swap .. coming in May 2014
Old 04-04-2014, 05:19 PM
slacker's Avatar
busy working on Erik's engine
Erik has opt. for our black painted headers , as well as our new clutch , filters , belts , plugs and t/belt and water pump .. so busy getting everything prepped and cleaned before the install
Old 04-05-2014, 03:58 PM
slacker's Avatar
just a little today ..
pulled the Alt apart to check condition of brushes .. all good
cleaned up and ready to install
also , got the starter pulled apart and checked contacts .. all good
bottom mount hole drilled and now ready to install
Old 04-23-2014, 05:04 PM
slacker's Avatar
more cleaning and prepping today .
got a bunch of parts blasted , and painted , including the oil pan .
also got the bottom end buttoned up . drilled the dipstick , tapped the old dipstick hole , new pickup , and attached the clean pan , oil pressure sensor , oil filter
flipped it back over , and started the top end .. as well as new water pump and timing pieces
and added some powder coated pieces
Old 04-23-2014, 05:17 PM
RBX
RBX's Avatar
nice work.
Old 04-23-2014, 07:05 PM
slacker's Avatar
thanks
Old 04-25-2014, 07:31 PM
slacker's Avatar
so now engine is ready .. couple of pieces to add , but I think we're ahead of the game
notice our new headers
basically ready to install
Quick Reply: toyotafiberglass - Erik's runner
