Looking For A Mechanic/Fabricator/Shop Put your location in your thread title when making an inquiry
3.4 L 5VZFE Rebuild in Baltimore, Maryalnd area
Old 08-27-2011, 10:04 AM
Stoctor's Avatar
Hello Guys/Gals,
My father just found out his crankshaft on his 3.4L 5VZFE is damaged due to the crank pulley falling off (mechanic did not tighten pulley to torque specifications). Since the engine needs to be removed and the engine has over 200k on it, I told him he should just rebuild the motor since he is already going to pay labor for removal/install.
My question is whether or not anyone knows of a reputable place around Baltimore that won't charge him a ridiculous amount for a rebuild while doing good work.
Any input would be greatly appreciated.
Thank you in advance for your time.
Old 09-01-2011, 05:02 AM
Potomacduck's Avatar
I have had good experience with this shop. I would call ahead and discuss the problem with them. The owner's name is Jeff and I know he is an honest mechanic.
They are about 30 miles west of Baltimore, but it might be worth the drive.
Four County Import Service
1302 Rising Ridge Road, Unit 20
Mt. Airy, MD 21771
Phone: 301-829-8600
Old 09-01-2011, 06:50 AM
Stoctor's Avatar
Thank you so much for the reply... I will give them a call today! I found a rebuilt engine for $2,400 and someone to put it in locally for $500.00, seems to be the best option so far.
Old 09-01-2011, 11:22 AM
drpdmazda's Avatar
if you can find someone to put it in for $500, you are getting a great deal in my opinion. i think book time to swap taht motor is 18 hours? i only know because i am going through a motor swap right now myself. did you look into getting a low mileage used motor? in my area they usually run about $1000. im about 3 hours north of you in pa though so prices may be a little different out there.
Old 12-29-2011, 05:25 AM
eduardo kang's Avatar
Ed's garage in Monkton. I believe one of their mechanics owns an 84 4runner, FJ80, and fixed up a 3rd gen for his daughter.
They're an honest shop in my opinion and only fix what's needed.
coleypull15
11-03-2015 07:41 AM
ChiefTetlow
08-10-2015 04:19 AM
snosurfer
08-05-2015 03:55 PM
94whiterunner
07-12-2015 07:15 PM
Cplmike
07-08-2015 08:47 PM
Quick Reply: 3.4 L 5VZFE Rebuild in Baltimore, Maryalnd area
