03+ 4Runner/GX470, & 05+ Tacomas (Build-Up Section) Post your build-ups here
Engine
Old 02-03-2013, 09:40 AM
Paul199's Avatar
Engine
Where can I get a motor for my 4runner?
Old 02-03-2013, 09:41 AM
HighLux's Avatar
What flavor motor? 4 or 6?
Year...model..etc.
Old 02-03-2013, 10:16 AM
Paul199's Avatar
It's a 4
Paul199's Avatar
And it's a 1990
Old 02-03-2013, 10:18 AM
Paul199's Avatar
5 speed
Old 02-03-2013, 10:38 AM
HighLux's Avatar
Did your motor blow up?
craigslist...junkyard...ebay..several engine rebuilders.
Whats your budget? Goals?
Old 02-03-2013, 10:42 AM
Paul199's Avatar
Hasn't blown yet I just bought it and one of the cylinders wasn't firing. I changed the plugs and it seems to be running better I'm no expert .
Old 02-03-2013, 10:45 AM
HighLux's Avatar
Well there you go then. Instead of a $1200 engine, you can just send me $50 if it make you feel better...lol
Old 02-03-2013, 10:55 AM
Paul199's Avatar
Haha yeah but I'm still not sure
Old 02-03-2013, 10:57 AM
HighLux's Avatar
First basic test of an engines health is a compression test.
Do a search on how to do it, and go get/borrow a compression tester.
Old 02-03-2013, 11:04 AM
Paul199's Avatar
Ok sounds good
Old 02-03-2013, 08:14 PM
2big4arunner's Avatar
If you plan on doing a motor swap you have a choice of a couple motor options. My favorite lately is a TDI engine from a 1997-2006 Jetta or Golf. Great MPG and about double the HP and torque from the 4 cylinder. I am gonna start building these in my spare time.
Old 02-05-2013, 04:08 AM
Paul199's Avatar
I'm also not sure how to adjust my E brake on my 4 runner. It has a lot of play in it the cable isn't broken any suggestions?
Old 02-05-2013, 10:47 PM
From the sounds of it I would suggest getting a Factory Service manual or a Haynes Repair manual and follow the instructions.
Regarding the motor... there is a place to get a slightly modified version of the 22re
http://www.lceperformance.com/22RE-E...-p/1002003.htm
It would be way better getting their gear instead of spending 3k on a short block from a standard rebuild shop. Just another thought that I Forgot about last time. In the end i would still do the TDI swap personally.. but thats just me
icentropy
09-16-2020 02:47 PM
RaginAsian91
Engine Swaps
03-30-2019 09:17 AM
jasonty
41
12-23-2018 01:00 PM
Seattle_Sign_Guy
07-12-2015 12:38 PM
razorman8669
07-12-2015 12:13 PM
Quick Reply: Engine
