Low and Slow. 00 Runner that will eventually be worthy. (pic heavy)
Old 01-16-2015, 12:02 PM
damnthemansam's Avatar
Well I figured it was about time to document my 4runner. Nothing crazy but it's slowly transforming to something I can be proud of.
2000 4runner 5spd Sport 4wd 225k miles.
Purchased for $3900 bone stock.
Current Mod List:
Suspension:
Toytec 3" lift
883 front coils
890 rear coils
OME shocks
Front diff drop kit
Pan hard drop bracket
Toytec adjustable upper control arms
new lower ball joints
16x8 D-window steelies from 4 wheel parts
285/75/16 off brand mudders
1.25" wheel spacers
Brakes:
Adam's rotors double slot
Power stop pads
new drums/shoes
stainless braid brake lines all around (extended rear)
new fluid
Body armor/offroad equip:
Trail gear rock sliders w/ custom gussets
Addicted-Offroad plate front bumper
Addicted-Offroad rear bumper
hitch mounted D-ring
Warn M8000-S winch
ARB on-board air w/ ARB single compressor
ARB rear air locker
Yakima roofrack w/ extention and spare tire mount
36" roof mounted light bar
18" bumper mounted light bar
Maintenance:
Timing belt/water pump/T-stat
All ACC belts
fuel filter
air filter
plugs
wires
1 coil pack (corroded where wire connects)
brakes
new clutch
new rear o2 sensor
all fluids
Odds and Ends:
Diff breather extension w/ new higher flow breather
Pioneer NEX-4100 double din w/back up cam and apple car play
power antenna on a switch (to retract when on the trail)
color matched cargo-caddy w/ spares/recovery gear/tools
WeatherTech rain guards
WeatherTech Trunk liner
clear corners
Clear/Amber LED blinkers
Magnaflow muffler
(edited just so the first picture wasn't old brake shoes)
NEW EDIT!
How she sits now now::
Started with brakes front and rear (adam's rotors) as the rear shoes were smoked.
Then it was straight to the upgrades.
toytec 3" lift
OME shocks
pan hard drop bracket
extended steel braided brake lines
diff drop kit
ARB air locker in the rear with compressor and on board air kit (no pics of that)
Then on to tires and wheels.
16x8 steelies with 285/75/16 cheapie mudders
$600 for 5 tires mounted and balanced
Yakima road warrior roof rack with extension and spare tire mount
Clear corners
Clear blinkers
Noise maker, good sound but not too loud:
Trip to pismo beach went swimmingly, almost. Sand storm right as we were setting up tents prevented us from camping so we rented a beach house.
Girls and their selfies.. Get outta the way!!
did a trip to sierra national forest and didn't get any pics except this one:
Then came tahoe. snow wheeling in virgin powder, reeeeaaaalll fun:
[YOUTUBE]
[/YOUTUBE]
Plowing
Next came the cheap-o rock sliders ($219 I think)
Fabbed up some nice gussets outta 3/16 mild steel. The sliders didn't seem strong enough by themselves.
VERY STRONG NOW!!
Decided to do a clutch while it was on the rack. Along with all fluids and rear diff service. ARB was taking a long time to lock up. Turns out the o-rings failed and the air line was full of oil. Got some new ones in there and works like a charm now.
Went to visit a friend in Portland OR, hit up browns camp for some guns and wheeling.
thats it for now!
Old 01-17-2015, 04:28 PM
Painted the sliders today, grip tape on the way for the top.
Old 01-19-2015, 07:48 AM
J03LC0LA's Avatar
Hey awesome truck man! I have a 99 limited and I was looking into almost the exact same upgrades as you. If you wouldn't mind sharing, how much was the toytec lift. And were the rims and tires only 600?
Old 01-20-2015, 10:12 AM
tires were $600 mounted and balanced, wheels were like $60-$70 each
lift was around $1600 with all brake lines, diff drop kit and pan hard extension.
Old 01-20-2015, 11:23 AM
jason in tn's Avatar
very good looking truck. I have 5 speed envy.
Old 01-20-2015, 03:47 PM
donomite49's Avatar
i'd like to have the OEM wheels
nice pics/runner.
Old 01-21-2015, 12:01 PM
J03LC0LA's Avatar
Nice! And everything's been good to you? No problems with anything?
Old 01-26-2015, 09:43 PM
Clutch would smell pretty bad when slipped on the trail or towing my boat, arb o-ring failed but not catastrophic, locker solenoid leaks occasionally, but other than that not a problem in the world. I need to take out and brake more stuff for an excuse to upgrade more components but she never ceases to amazing every time I test her.
Old 05-30-2015, 07:15 PM
Went to Hollister this weekend, waiting for Scotty from Addicted Offroad to get back from Moab so he can build me some bumpers... I definitely needed them this weekend. Had to use my spare tire to get out of a hole. That ditch took me about 45 mins to get through. Really fun day.
Old 06-02-2015, 11:28 AM
kdf8454's Avatar
Looks like you're enjoying this to the fullest - good score on the tires
Old 07-28-2015, 06:10 PM
Exciting news!
My bumpers showed up today, after 8 miserable weeks of being completely left out of the loop. Thanks to Scotty from Addicted Off-road for putting up with my constant emails. A little more communication would have been appreciated but they are here and they are purty.
Also have a Warn M8000 w/ synthetic rope to accompany these bad larrys.
Old 08-13-2015, 07:14 AM
update:
Mounting lightbar/switches for light bars
36" fit perfect inside the yamika roof rack
Zombie = roof, Fog = bumper
found a hole under the roof rack that works perfect:
powder coat:
welding on front cross beam (as per scotty at addicted) for added strength when winching:
next came fitting warn M8000. really tight fit, lucky I got the M8000 instead of VR8000 (control head is smaller) as I dont think the VR would fit.
bumper light bar:
had to modify warn control head bracket to fit with grill installed
getting there
all done, time to service: timing belt/oil change/brakes/shoe adjustment/tire rotation
absolutely loving this front end
service position
probably should have done the timing belt first AND THEN the bumper with a big stinger, but this worked pretty well
aiming light bars
no pictures but i put in heavy front springs to support bumper/winch sits nice and high in the front now.
and these are the last pics (no roof light bar cause I was waiting for brackets).
hoping to get someone to take proper pics soon as mine dont really do it justice
all done. enjoy. I know I do.
Old 08-20-2015, 06:01 PM
4Runnin2000's Avatar
Really liking the front and rear bumper and armor! Very nice rig!
Old 08-25-2015, 06:38 AM
man this forum is dead huh?
Old 08-25-2015, 10:57 AM
Yep, lots of great threads around here that get "0" attention.
Old 08-25-2015, 07:59 PM
I was just thinking the same thing... Doesn't seem to have anyone on here anymore.
Old 05-09-2017, 11:00 AM
Teamroper's Avatar
Love the front and rear bumpers. Great job!!
Old 05-24-2017, 04:35 PM
ericwudi0830's Avatar
Those tires look like they can tread anything. Awesome!
6th Gear
19
12-10-2019 07:31 AM
noahstancik
07-10-2015 11:18 AM
B. Graves
07-03-2015 04:10 AM
Mr.Black
06-21-2015 10:17 AM
Quick Reply: Low and Slow. 00 Runner that will eventually be worthy. (pic heavy)
