Yeah, I'm a noob still. Tire question
Old 07-17-2007, 12:37 PM
deathrunner's Avatar
I feel like such an assclown for asking this. Believe me, I searched and not just here.
We got a 98 2wd 4runner. Want to put on some tires. I have some bfg Trail 31x10.50's will these fit without rubbing?
If lift is needed, how much for 31's?
What gearing does a 2.7 have?
Yeah, I know.....dumb questions.
Old 07-17-2007, 12:58 PM
terryjmatthew's Avatar
You should be able to clear 31's at stock height. You might have a tiny bit of rubbing if equipped with running boards.
** edit**
I think all 4cyl's came w/ 4.10's.
Old 07-17-2007, 01:12 PM
Rock Slide's Avatar
Hey at least you're asking a question, rather than assuming (which others do more often than not.)
265/70/16 is the equiv to a 31x10.50. Therefore you should be okay. I had a '99 2wd w/ the 70s on there and it was fine.
Old 07-17-2007, 07:37 PM
unitofstuff's Avatar
My '98 4wd's stock size was 265/70/16, which, as stated, is 31x10.5. I'd say it shouldn't rub at all.
Old 07-17-2007, 07:43 PM
locked stock 84's Avatar
https://www.yotatech.com/forums/f120/toyota-faq-66255/
look here, bout half way down.
Old 07-17-2007, 08:21 PM
Originally Posted by locked stock 84
I saw the part about 1st gen tire fitment. Somehow I am still missing the 3rd gen info.
But anyway, thanks for the responses.
4.10s check
31's no rubbing good to know. Already took off the running boards.
Old 07-17-2007, 08:35 PM
Marc P's Avatar
I thought you liked getting rubbed
Old 07-17-2007, 09:00 PM
BajaRunner's Avatar
So are you guys on the same course, at the same moment of time in your avatars? Thats cute.
Old 07-17-2007, 09:09 PM
[QUOTE]For Tacomas and could work with 3rd gen Runners:http://www.4crawler.com/4x4/ForSale/...ireChart.shtml[QUOTE]
Old 07-17-2007, 09:14 PM
drguitarum2005's Avatar
Location: Houston (home), Atlanta (school), Cincinnati (work)
i had slightly bigger (265/75/16) on my stock '00 4runner with running boards and no issue at all. you will be fine
Old 07-17-2007, 09:30 PM
big_blue_goat's Avatar
31's?
My uncle put 33's on his 4-runner at stock height. Not if your gonna go wheeling but 31's or even 32X1150's would fit fine. word, they all came with 4.10's
Old 07-18-2007, 07:02 AM
[QUOTE=locked stock 84;50575033][QUOTE]For Tacomas and could work with 3rd gen Runners:http://www.4crawler.com/4x4/ForSale/...ireChart.shtmlYou win, I'm blind.
Old 07-18-2007, 07:31 AM
consalvochris's Avatar
Better have no less than a 6inch body lift.....
Old 07-18-2007, 08:44 AM
hahahaha sweet
jerusry
10-19-2015 05:28 PM
coffey50
07-28-2015 10:55 AM
DrZero
18
07-24-2015 11:31 PM
MTLroadierunner
07-20-2015 03:07 PM
Quick Reply: Yeah, I'm a noob still. Tire question
