Xtracab (N65) original tiresizes in US?
My friend wants to know. Here it´s only one: 205R16. Is there any bigger available? Here in Finland you can put only 2" larger than original tires under your truck, bigger are unlegal. But the biggest tire in same modelserie can be the referencetire. Do you understand me?
So, is there 31x10.50R15 or 10R15? Could someone scan me the page of Chassis & Body -manual if there is mentioned this size? Thanks.
Assuming 4wd, early models (at least starting in 1984) had 225/75R15, then a 31x10.50R15 option was added, which changed to and 265/70R16.
Currently there are 225/75R15, 225/75R16, 265/70R16 and 265/65R17 available.
Easiest way would probably be to get a factory brochure. They usually list the tires sizes.
Originally Posted by hafftrak
My '91 had 31x10.5x15 tires from the factory. I'll see if there is something in the manual I can scan for ya.
But I´m seeking N65-models (older with solid axles)...
P.S. Thanks boogyman.
