wow these OEM shocks are expensive
Old 02-11-2008, 05:52 AM
mkgarrison5's Avatar
out of curiosity i called my local yota dealership about new front shock absorbers and they wanted $152.11 EACH! to replace both it would be $482... these are not TRD shocks either just the basic 4x4 shocks- i assume they are tokico (sp).. what do you guys think about that price and how often do you change your front shocks? my taco has leaf springs in the rear and i dont plan on replacing those anytime soon.. the truck has 104k miles on her
Old 02-11-2008, 06:12 AM
infiltrator's Avatar
104, i think you should be fine on shocks for a little, but depends on how hard you are on them. definately you can get some good shocks all around and springs and have them put in for that much. im talking all around!!!! so do that, go to eshocks.com (cheapest shock place) and get yourself some and get them put in. NEVER GO TO THE DEALERSHIP! unless you own a bmw or something, but then if you do, you probably have the money.
Old 02-11-2008, 06:23 AM
now those prices are much better.. anyone know the difference in ride qualitly and preference over the stock Tokico's and the Bilstein heavy duty shocks and strutts?? to me i would think the heavy duty shocks would be more stable and sway less BUT give a bumpier ride. am i correct on this?
Old 02-11-2008, 06:29 AM
CTRJ's Avatar
You can get some Bilsteins for less than $100 each.
Old 02-11-2008, 07:03 AM
Tug
Tug's Avatar
I just paid $160.00 for the front and $130.00 for the rear (Biltsein). I plan on installing the rear myself but dont feel comfortable installing the front due to the spring compressor thats needed. I would suggest ordering them on line and doing the same, its amazing how much money you'll save.
Old 02-11-2008, 07:15 AM
and yes buying them online will save tons of $$... the main reason why i wanted to change them is bc the factory ones that i have on now sway when turning sharp and its kinda freaky. but that could be the worn out tires i have on there too and they are hard as a rock (bf long trails with 50k+ miles on them)......... i am going to buy tires first and see what she does then. those BF's suck esp after a bunch of miles
Old 02-11-2008, 07:29 AM
CTRJ's Avatar
You can get Tokico front struts for $47 each from Autopartswarehouse.com.
And sorry, I was look at rear shocks when I said they were less than $100.
Old 02-11-2008, 07:34 AM
those are for 2 wheel drive tacos...
Old 02-11-2008, 07:58 AM
Godzilla's Avatar
You should not go to the dealer for any suspension products since you will lose on both money and peformance. There are many shock options in the aftermarket that will provide the performance you require for a much cheaper price. The fronts will generally be more than the rears. OME, Bilstein, Tokico, etc.so many good options.
The only "good" thing about getting OEM suspension parts is that they come with a lifetime warranty.(at least they do here)
Old 02-11-2008, 08:15 AM
[QUOTE=Godzilla;50748294]You should not go to the dealer for any suspension products since you will lose on both money and peformance. There are many shock options in the aftermarket that will provide the performance you require for a much cheaper price. The fronts will generally be more than the rears. OME, Bilstein, Tokico, etc.so many good options.
The only "good" thing about getting OEM suspension parts is that they come with a lifetime warranty.(at least they do here)[/QUOT
uh i dont think they do here... something to look into i suppose
Old 02-11-2008, 08:25 AM
CTRJ's Avatar
Autozone carries Bilstein's for $80 each.
Old 02-11-2008, 08:27 AM
CTRJ's Avatar
Toyota parts have a 1 year warranty. If they were lifetime, I'd be out of a job!
Old 02-11-2008, 10:20 AM
MTL_4runner's Avatar
Mike, give Toyota of Dallas a call, those prices are way high.
Old 02-11-2008, 10:28 AM
89macrunner's Avatar
i think the monroe sensatracs my dad put on my first gen cost less than $40 each..and that truck didnt ride great by any means but it rode fine. Actully, I thought it rode great untill i got my tacoma with coilovers and fancy rear leaves.
Old 02-11-2008, 10:48 AM
Godzilla's Avatar
Actually I have a warranty card from the Toyota dealership here when they put on OEM rear shocks before I got my OME's. It says lifetime warranty as long as its the same owner that got the shocks. This is in Canaduh though.
Old 02-11-2008, 10:54 AM
waskillywabbit's Avatar
Stock is just that. HD is made for off-road and more loading and will be stiffer than your stock feel shock. So if your truck is a stock pavement pounder no need for HD IMO.
Old 02-11-2008, 11:07 AM
X-AWDriver's Avatar
www.shox.com has Tokicos (OEM) for $211 for all 4 and Billies for $289.
Old 02-11-2008, 11:23 AM
211 isnt bad and yes its a pavement pounder. i drive about 30k a year give or take. it does see off road but not much just during hunting season and some ponds i go to are off the beaten path but not like what most of you guys do so i may go with the cheaper OEM tokicos eventually
Old 02-11-2008, 01:34 PM
The Bils HDs will give a more controlled ride but are stiffer. You get to feel every little bump more than before. I am thinking of getting rid of mine and put Tokico Trekmasters on instead.
justdifferentials
Just Differentials
06-13-2022 07:40 PM
choppe777
05-16-2016 08:00 AM
HiLuxer
01-06-2016 11:34 AM
dbd6604
10-11-2015 05:30 PM
justdifferentials
09-05-2015 06:52 PM
Quick Reply: wow these OEM shocks are expensive
