Would this fit my 1997 4wd 4Runner? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 06-12-2004, 04:08 PM   #1 (permalink)
Send a message via AIM to ravencr Send a message via Yahoo to ravencr
http://www.tuffcountry.com/suspensio...ta_tacoma.html
Chris
P.S. I'm interested in the 5" kit only.
ravencr is offline
Old 06-12-2004, 06:10 PM   #2 (permalink)
Morr's Avatar
Quote:
Chris
Don't know about the front end, but the tacoma uses leaf springs at the rear so those parts will not fit your 4Runner as it uses coil springs
__________________
Maurice
1996 Toyota Hilux Surf SSR-G 3.0TD Auto
Fuelled by Vegetable oil
Mods: Interior switches and panels with blue LED's. Towbar. 4Runner load cover. Daystar 2.5" lift. 1/4" Wheel Spacers. 285/75/16 BFG A/T's
Waiting Mods: Recaro Seats to be fitted.
Hilux Surf FAQ at www.hiluxsurf.eu
Web hosting with 24/7 support and free domain names!
Morr is offline
Old 06-12-2004, 07:18 PM   #3 (permalink)
dragr1's Avatar
Chris
Go for it Chris! I don't see why it wouldn't work (I assume you mean front only).
__________________
1985 4Runner Dual e-lockers, dual cases, yada yada
1996 4runner, lifted, 2 lockers, 315 KM2's, IFS and more
'00 Suburban 2500 4x4
'07 Tacoma Double Cab 4wd TRD
'02 Lexus IS300
1991 Tiffin Allegro 31' Class A
dragr1 is offline
Old 06-12-2004, 09:45 PM   #4 (permalink)
Yeah, I'm not worried about the rear. I'm just concerned about the front end. I figure that I need some extra height to help me get over the bigger rocks and not hang up as much, and I'm wondering if this kit for the Tacoma's will fit the front of my 4Runner. If so, I may be going this route instead of a SAS or long travel IFS kit. I don't know yet, though, just weighing my options.
Chris
ravencr is offline
Old 06-12-2004, 09:55 PM   #5 (permalink)
dbikeman's Avatar
Send a message via AIM to dbikeman
From what Ive read it seems like it should work. The Procomp 4" taco lift fits the 4runner i do believe.
__________________
David Anderson
Hit me up on AIM at Dbikeman85(im always on)
98 4runner SR5 w/99bumper
99 scoop hood and 99 headlights
Clarion VRX935VD 7" flip out, Excessive Amperage 200amp alt.
Kicker Kx1200.1 amp, Eclipse Titanium 12
Stinger 0 gauge and stinger cap. Xstatic Batcap
Jaos Aero Billet grille Jason B clears in the corners and bumpers
Clear Tailights
Magnaflow 18" with 3" Magnaflow tip
dbikeman is offline
Old 06-12-2004, 09:57 PM   #6 (permalink)
Doesn't the pro comp kit have some sort of spacers that cause it to get out of alignment pretty easily, though?
Chris
ravencr is offline
Old 06-12-2004, 10:37 PM   #7 (permalink)
Send a message via AIM to justinh
the only problem with it is that while you create room for bigger tires you do lose ground clearance. steve has proven that you don't need one to run 35's and you should have more ground clearance with your current set-up and 35's than with the drop set-up and 35's. I understand wanting to go bigger, 285's and 3" is starting to look really small on my 4runner.
justinh is offline
Old 06-12-2004, 10:54 PM   #8 (permalink)
As far as clearance goes, everything gets raised except for the subframe, so clearance definitely goes up. Think about it again, and you'll see what I mean.
Chris
ravencr is offline
Old 06-12-2004, 10:56 PM   #9 (permalink)
sschaefer3's Avatar
Yes it will fit, only the front though. Your on your own for the rear.
__________________
Steve Schaefer
WWW.SonoranSteel.Com
Suspension Lift Kits * Rock Sliders * Straight Axle Conversions * 4Runner/FJC Rubicon Express Lower Links * Accessories * Daystar Products Dealer * TJM Bull Bar Dealer * Deaver Leaf Spring Dealer * Tokico & Bilstein Shock Dealer * ViAir Dealer * Total Chaos Dealer * TOYTEC Dealer * and like everyone else a Trail Gear Dealer
sschaefer3 is offline
Old 06-12-2004, 10:57 PM   #10 (permalink)
Sweet! I may be going this route, but I'm not totally for sure yet. Thanks for the confirmation Steve!
Chris
ravencr is offline
Old 06-13-2004, 12:01 AM   #11 (permalink)
unless it is different than every other drop bracket lift out there which it may be, i have only seen one installed and that was on ttora and i didn't pay much attention to it you won't have much if any more ground clearance than stock except what you get from your tires. of course even with the set ups that we run now we don't gain much. but the new cross memeber bolts on to the bottom of the old stuff which provides a lower mounting position for the lower control arms which is why the taller steering knuckles are required or in the case of the pro-comp lift the spacers. again, the tough country may be different but this is the basic principle behind the drop lifts. i do agree with you that this looks like a much more sturdy lift than the pro comp and it a fair amount cheaper than the fab-tech.
i guess my reasoning behind it is, if you can fit 35's with what you have now do you really want or need the extra lift, wanting and needing it are both valid options for getting it. i mean most of the stuff i buy i don't need but i sure do want! good luck with it all, whichever direction you choose. i think that the touch country setup with some good coilovers and camburg/all pro upper control arms could make for a nice set up.
justinh is offline
Old 06-13-2004, 06:56 AM   #12 (permalink)
Everything you've said is correct, except for the extra ground clearance gained. If you're talking about the ground clearance I'll gain underneath the front end, then I'll gain zero. But, I'm talking about the extra ground clearance I'll gain underneath the entire truck. That's what I'm talking about. I could care less about the clearance underneath the front end, because there's only one way to increase that and that's with bigger tires or a long travel IFS kit. But, as far as raising the frame up and out of the way of big rocks, a SAS or this kind of IFS kit is the only way to do it, outside of larger tires of course. Make sense?
Chris
P.S. That link you provided doesn't work for me.
ravencr is offline
Old 06-13-2004, 07:32 AM   #13 (permalink)
sschaefer3's Avatar
It worked for me, but that's not a "lift" for a truck.
__________________
Steve Schaefer
Old 06-13-2004, 07:34 AM   #14 (permalink)
Quote:
I'll second that one! Nice pics, though.
Chris
ravencr is offline
Old 06-13-2004, 07:57 AM   #15 (permalink)
http://www.parksoffroad.com/tacoma%2...uffcountry.htm
try this one, i don't know how the other one even got in there, and i didn't find any pics on that other one. there are some wierd yahoo groups out there i didn't even know exisisted thats for sure!
and i was talking about the clearance under the front differential. if i remember correctly the tough country is actually better about this than other lifts out there, for some reason i remember reading somewhere the not all of the lift is acheived through dropping the cross member.
justinh is offline
Old 06-13-2004, 08:22 AM   #16 (permalink)
RTdawgs's Avatar
from the Park's Off-Road Tough Country installation page:
" I also had looked at the Pro-Comp 4 inch lift, but the spacer they use on top of the factory spindle with u-bolts and a bracket to re-enforce the spindle does not look like a good idea. I heard horror stories about the alignment going out after every off-road trip and such and decided it was not the way to go. The Tuff Country kit comes with new heavy duty spindles to avoid this problem. The Tuff Country kit also comes with new upper ball joints installed so you dont have to worry about getting the old ones out in one piece."
__________________
Ryan
New: 2008 4Runner Sport. Mild, not wild.
Old: 2000 4Runner 305s, Locker, TJM, Warn, Skids, Sliders, SC
RTdawgs is offline
Old 06-13-2004, 08:25 AM   #17 (permalink)
Yep, and I can't find a better kit yet. I'm going to find out if I can get just the parts for the frontend of this lift from Tuff Country, minus the shocks, etc.
Chris
ravencr is offline
Old 06-13-2004, 08:36 AM   #18 (permalink)
i am pretty sure that you can, i remember reading over on ttora about someone doing that. Good luck with it! I looked at some of the yoko's the other day, someone on campus had a set on his k5, with the open grooves towards the outer side of the tires i could see how the would work better in the mud than i originally thought. I also didn't realize how cheap they were, i saw $135 a tire for 315/75/16 somewhere on-line.
justinh is offline
Old 06-13-2004, 09:18 AM   #19 (permalink)
Yepper, I'm going to get the Yoko's unless another tire that's better and cheaper comes out before I do it. It's not worth it to spend nearly twice as much for a tire that just looks better, and doesn't perform any better.
Chris
ravencr is offline
Old 06-13-2004, 01:52 PM   #20 (permalink)
i didn't realize they are as cheap as they are, even if you had to give up some performance it would probably be worth it. with your rear locker and plans for a front locker you more than overcome anything these tires may lack. they really may be the best compromise for a rig like yours. i would hesitate to run them on my rig now being open/open but with the lockers waiting to be installed i wouldn't hesitate. reassessing what my rig needs to be (getting married July 10th, working full time and finishing school) they probably should be my next tire, whether i will get over the lack of "bling" or not is a different story good luck with yours chris.
justinh is offline
Old 06-13-2004, 02:18 PM   #21 (permalink)
Super Moderator-Sponsoring Member
Staff
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
Talking Ouch
waskillywabbit is offline
Old 06-13-2004, 04:15 PM   #22 (permalink)
I wouldn't hesitate to run them regardless of the setup you have. They are great tires, along with my REVO's. You don't have to have all these aggressive looking tires to be a greate off-roader. In fact most of them suck and just look good. I've said it before, but I'llput my REVO's up against any comparably equiped 4runner with any other tire on the market, and I guarantee they'll either hang right with them or pass them up.
Chris
ravencr is offline
Old 06-13-2004, 04:17 PM   #23 (permalink)
Quote:
Originally Posted by waskillywabbit
The only reason his angles are the way they are, is that he has his King's cranked up too much. The Tuff Country lift itself doesn't alter the CV angles at all. In fact with this type of lift, you can maintain stock CV angles, and have 5" of lift.
Chris
ravencr is offline
Old 06-13-2004, 07:26 PM   #24 (permalink)
dragr1's Avatar
Chris
Get some 35x10.50 Swamper SSR's Chris!
__________________
'02 Lexus IS300
dragr1 is offline
Old 06-14-2004, 02:49 AM   #25 (permalink)
Quote:
I saw those, and I could definitely fit them on my stock rims, but I'm probably wanting at least a 12.50 or possibly a 13.50 if I can do enough fender trimming to make them work. I'd get 37x11.50's if someone made them!!
Chris
ravencr is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Will springs and shocks from a 2003 4Runner fit a 1997 4Runner?? gkatmar Newbie Tech Section 0 04-13-2007 11:25 AM
tire/wheel fit question???? 1997 4runner werdwerd 95.5-2004 Tacomas & 96-2002 4Runners 9 02-20-2006 07:23 PM
Will a 1997 4Runner rear diff fit in a 1994??? EOD30 95.5-2004 Tacomas & 96-2002 4Runners 5 10-22-2004 01:47 PM
Will a 3Rd member from 1997 4Runner fit into a 1986 4Runner? Mojo_Risin 95.5-2004 Tacomas & 96-2002 4Runners 1 03-15-2003 08:30 AM
2009 InternetBrands, Inc.
