Would this airflow idea work?
A buddy of mine has a 92 toy truck with the hood rusting on the drivers side front corner. Instead of replacing the entire hood an idea came to mind. What if you took and basically sealed the airfilter corner with maybe plexy glass bordering the air filter (open element style) into that corner. Now the air filter would not breate off of the engine air. With that rusted corner if he cut it out and constructed it with a mesh screen or pick up tube design of some sort would that not increase HP? The engine would then be sucking cooler cleaner air from outside. good idea or chit? Blue
It would basically be a cold air intake of sorts like ricers use. They run their tubes to the lower bumper to suck air that being down there tends to get dusty or contain exhaust fumes. Any opinions at all bout this? Blue
Originally posted by jimabena74
cooler denser air will gain more performance, however, what about the rain and elements? im thinking bad idea here....
A '92 shouldn't be breathing off engine air. It should already be ducted to a cool air source.
That said, your method may work, and may give you a little boost as high(er) speeds when the air pressure at the front of the vehicle builds up. You've got to open to that high pressure though. Open to the top of the hood will not get it. You've got to be open to the front, and at the front of the vehicle to gain it.
Only other very real issue from your description is water. If it's open to the top, rain can and will get into it. Parked during a gulley washer of a storm can have this fill up the intake with water. So ensure you've got a water drain at the bottom of the box. Ensure it's big enough to handle the potential rain water flow.
Originally posted by Toyminator
If there was a substantial size water drain, wouldnt that eliminate the "fresh air induction"?
Suprarossa
07-06-2015 05:21 AM
