Is it worth taking motor apart to clean?
I have 180,000 miles on my 2.7L. I replaced the header gasket and noticed a lot of carbon buildup. So I wondered if it's ever worth taking the motor apart to clean everything piece by piece and replacing all seals and gaskets?
Or is it a situation where you'll start having lots of other problems because of wear and tear on things for 13 years?
I don't want to put a lot of $ into it but if it will run better, get better mileage, and stop the "clicking" I hear from the lifters - is it worth it? Or just do the seafoam through the intake manifold and adding it to the oil (along with mystery oil) for a couple days and change my oil?
My mileage has begun to suck.
No real need to pull it apart to clean it. I would recommend a valve adjustment, that is the reason, for the clicking; I'm sure of it.
Just run some seafoam and you will be cherry.
If you would still like to clean the internals really good, there is a really cool trick to help out:
-Drain the oil
-Fill the block up with diesel just like you would with oil.
-disable the ignition so you do not get spark.
-crank the starter several time, but no longer then 15 seconds. let the engine sit, for 2minutes, and crank again.
-crank as many times as you wish until you feel your engine is clean.
-drain diesel, change oil filter, and fill up with oil just like an oil change.
Happy cleaning.
-Drain the oil
Happy cleaning.
-Drain the oil
Happy cleaning.
-Drain the oil
Happy cleaning.
Clicking is most likely caused by valves being out of spec. Not real difficult to adjust. If you were going to take it apart to clean it, might as well throw a rebuild at it. But, you'll probably be okay with Seafoaming it and adjusting the valves. New plugs, wires and filters never hurt anything either...
Yeh, who needs Chevron-with-tecron? I heard about the trick about ten years ago. Works well if an engine was neglected, and never had an oil change, but I could never neglect my Yota.
Don't pull apart an OEM engine for no reason, it will never go back together with the same tolerances it had when you pulled it apart. Better off just leaving it alone.
If you want to clean it out do a water/seafoam treatment.
-Drain the oil
Happy cleaning.
-Drain the oil
Happy cleaning.
Thanks
Once the engine is knocking though you are pretty much screwed. Maybe some thick oil will buy you some time.
-Drain the oil
Happy cleaning.
-Drain the oil
Happy cleaning.
09-04-2015 09:27 AM
WTB[PacSoWest]: Looking for a electric locking differential motor/ actuator
AaronM
07-08-2015 07:15 PM
skoti89
07-08-2015 12:05 AM
