A word on NGK's
A word on NGK's
I had a rough running condition on my 95 3.0, it was an intermittent miss at idle and through the RPM the range. After changing the cap and rotor I decided to change the plugs. I was surprised to see half the ceramic insulator on the old NGK missing on cyl #6. Since I bought the truck used I can only assume that it was lost in the cylinder and hopefully shot out the tailpipe before it did much, if any damage.
Anyway I replaced it with new plugs and all is fine. My vacuum gauge is still steady so, I don't have bad valves or rings.
I thought this would just be fuel for thought for when these conditions present themselves. And a reminder to check the simple things.
One thought though, what condition other than detonation causes the insulator to crack? This 3.0 runs really strong without pinging or noise or any other complaints. Could it be the result of defective materials or is there something else to look for?
Guest
Posts: n/a
Guest
Posts: n/a
Originally Posted by Dr. Zhivago
[Off topic]
With regards to Bill's signature. I would have kept the old truck, too...
G
[/Off topic]
G
[/Off topic]
However I've been looking for a mint, low mileage 98-00 Limited, in Calgary, to purchase, lift a little, and enjoy as a personal 'beater'.
anniesball
09-07-2015 11:20 AM
