| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
wont start
#2 (permalink) |
Found some info that might help you out. It's PDF so you'll need Adobe Acrobat to view it.
www.net-impress.com/4runner/cd/F_BASIC2.PDF If that link doesn't work, do a search for "4Runner Coil problem" and look for the link that says, "F - Basic testing - 3.0". |
#3 (permalink) |
wont start
would all these tests be the same for 87 4runner with 22re (4cyl)
thanks for the info by the by |
#4 (permalink) |
i have 6 flashes when i cross those 2 leads te1-e1
any help |
#5 (permalink) |
According to Haynes, 6 blinks = RPM Signal with possible trouble areas of:
1. Igniter circuit 2. Igniter 3. Distributor 4. Computer I am not aware of a test for the igniter. |
#6 (permalink) |
hey hammerdown6 do you know of a way to check the computer. i tried the one out of the 88 and it does the exact same thing and that one seems to have been replaced.
#7 (permalink) |
MAke sure to test yer air sensor.....
__________________
~ Those who hesitate are not only lost, but miles from the next exit! ~ 1990 4Runner SR5, 3.0L V6, 5-Spd. ~ 3" BL ~ OME 900 ~ 32x1150 Dueler AT's ~ Magnaflow Cat-Back ~ Optima ~ Manual Hub Conversion ~ FLX-165 ~ Hella 530s ~ ISR |
#8 (permalink) |
Hi all, I am having the same problem ans same symptoms as Headhunter, i've tested the efi main relay, open circuit relay.
I have nice spark at the plugs but nothing coming from the igniter plug with the three wires that feed the ECU, ie. the black and red, black and white and black and yellow. I notice thta there is no pulse at the injectors and from looking at the schematic on all data I see that the black and red seems to feed the injectors I may be wrong. My question is should i get any voltage coming out of the igniter plug when the key is on and when the engine is cranking over? I am not clear on this one. The cold start timing switch and injector check out fine and the engine starts just momentarily from the small amount coming from the cold start injector. Any help or ideas would be appreciated. Thanks TC. 88 4 runner bush buggy 87 4 runner great shape dont run. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| wont start please help | 95yota4 | 86-95 Trucks & 4Runners | 5 | 06-25-2007 08:04 PM |
| 3.0 wont start | 4rnr | 86-95 Trucks & 4Runners | 18 | 03-19-2007 10:30 PM |
| Recently rolled 4-runner now it wont start, why wont it ?? | gtpunk18 | 86-95 Trucks & 4Runners | 22 | 01-24-2007 10:25 PM |
| it just wont start | tk0218 | 86-95 Trucks & 4Runners | 2 | 03-06-2006 05:50 AM |
| HELP!!!!!!!!!!!!!!!!!!Still wont start | cobrahunter | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 08-08-2004 06:42 AM |
