Wiring issues
Old 07-07-2008, 09:17 PM
GONZO97's Avatar
Thumbs down Wiring issues
Hey, so ive been trying to wire up four lights to one relay switch and i cant get it to work........Any suggestions? For some reason when i first switched them on only two lit up and now i cant get any to light up..... am i missing something?
Old 07-08-2008, 06:30 AM
willardtx's Avatar
You might be overloading the relay. If I were you I would run two relays off on switch or get a bigger relay for the application you are attempting.
Old 07-08-2008, 08:24 AM
4x4phil's Avatar
One realay per pair of lights and you should be golden
check here for further help
http://www.kchilites.com/faq.aspx#InstallGuides
Old 07-08-2008, 10:16 PM
GONZO97's Avatar
Well i figured out the wiring issues...we had the ground hooked up to the light bar which wasnt strong enough so by placing a better ground all lights should work....if everything goes as planned ill have pictures by tomorrow
Old 07-08-2008, 11:50 PM
algranger's Avatar
i used a heavy relay and one heavy hot wire that i spliced into a bunch of times for each of my lights no problems yet.
MO transplant
04-23-2023 11:58 AM
Sleaker
08-26-2020 06:03 AM
raptor510
02-17-2017 07:11 AM
smiley52
07-11-2015 05:16 AM
nick b
07-11-2015 04:38 AM
Quick Reply: Wiring issues
