Wiring Door Speakers
Well I finally have everything ready to install my amps and subs that have been paitiently waiting their deployment. I have a question about running the speaker wire from the amp to my 4 door speakers. If anyone had any detialed info on this, I would greatly appreciate it. I am going to put the front stage amp under the front passenger seat and I want to hide the wires as much as possible for a quality install.
I just tapped into the wires where the came into the oem headunit and ran the wires back to the amp from there. I am only running about 25W/RMS to them so reusing the factory wire doesn't really matter.
thanks. i will be running 75X4 to the door speakers. do you think i could just tap into those wires or will it be better if i just ran new wires?
Its nothing too difficult. Just take the boot loose between the doors and run them through there then put the boot back in. I would deff. recommend new speaker wire. If your looking for some wire Ive had good luck with knukonceptz.com Seems to be of good quality at a good price.
I run Stinger wires and all accesories(distribution blocks and capacitors and fuses) and all Kicker speakers and subs. I'm trying to get sponsored though.
FS[PacNorWest]: 1987 Toyota 4Runner $1800 Whidbey Island, WA
coreyedwards7611
01-16-2016 06:38 PM
94yotaky
07-23-2015 07:50 AM
