Wiring
Wiring
I've seen several people meniton the idea of trying to swap in the new 4.7 V8 into their 4runners, but how would you wire for VVT? Would it be possible to use only the V8 ecu? or would you have to use both?
I don't think so. One engine, one ECU. I think it is easier to use the ECU that mates to the engine, but there are most likely work arounds if you want to use your 3.0 ECU. I'm no authority, just what I've picked up from reading. You know the 4.7 engines are a fortune - when you can find them... I'm considering the supra swap personally.
Originally posted by Praufet
I'm actually considering a 1zz or 2zz swap. My goal is to have the most fuel efficient 4runner.
ToyoToler
08-08-2015 08:43 AM
