will tundra suspension bolt on a 97 4runnner.>?
Old 12-02-2004, 05:56 PM
2wheelBLACKOUT's Avatar
will tundra suspension bolt on a 97 4runnner.?
just like the topic says.....i have a pair 2000 tundra non trd spring and struts assembly..i want to know if it will bolt directly on my 4runner as is.
Old 12-02-2004, 06:15 PM
bamachem's Avatar
No.
Take your Strut assemblies out of your runner and break them down (have it done at a shop or read up on how to do it CAREFULLY). Break down the Tundra strut assemblies. Put the 4runner top plate (with three bolts sticking up) on the Tundra assembly.
Once that's done, it will be a direct bolt-on. If they are non-TRD 2WD assemblies, then you'll be the same height and just a tad bit stiffer ride. If they are non-TRD 4WD assemblies, then you'll be 1.5" higher and a tad bit stiffer ride.
06-01-2021 01:51 PM
nvdesertrunner
05-11-2020 08:18 PM
matrad
08-08-2015 03:00 PM
Suprarossa
07-06-2015 05:21 AM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: will tundra suspension bolt on a 97 4runnner.>?
