Will a 84 4wd truck wheels fit on a 83 2wd
I can have some donated (read free ) I just want to make sure wheels will bolt up. Mine is 5 lug. The tires are 31 inches.
Not hard at all... if you want to lift the rear 6" at the same time. A little bit harder to keep it all the same. 4wd trucks are spring-over-axle (SOA), 2wd are spring-under axle (SUA). To swap in a complete 4wd axle, you have to weld on a couple new spring perches under the axle.
GreenLion
06-07-2021 10:49 AM
