will 4.88 stock gears from v-6 auto fit ....
Old 04-24-2005, 01:54 PM
airrikk17's Avatar
i currently have yukon 4.88 gears in my 1995 4runner, but recently i lost the pinion gear on the rear end , total loss striped completly.
i called one 4wheel parts supplier and they said the aftermarket 4.88 gears have been on back order for some time , due to some kind of manufacturing flaw. the use of shims ot make it fit essentially .
well after some research i find out the v-6 automatics came with 4.88 from the factory, in this thinking, wouldnt the stock ring and pionion from a auto v-6 fit my aftermarket application for 4.88's in my 5 speed ?
is there some kind of difference between the auto's and 5 speeds ?
to make matters complicated a bit more , i have a rear detriot locker, so maybe the stock ring and pinion from the auto v-6 isnt strong enough to deal with the locker.
any help greatly appreciated, that shop its sitting at , tried calling around on saturday to find the ring and pinion set , but of course everything was closed or couldnt check .
if i can pick up a set fro ma junkyard out of a v-6 auto, i might just trailer the vehicle home and start hitting the junkyards instead.
airrikk17
Old 04-24-2005, 03:35 PM
Adam F's Avatar
You can bolt the whole 3rd member up to your truck no problem. But from what I understand, the stock 4.88 gears will only work in a 4.88 3rd member, meaning, you cannot take just the ring and pinion out of the stock 3rd member and put it in a different 3rd member.
Not sure if the detroit would work in a factory 4.88 diff either, I'm thinking not though.
Old 04-24-2005, 03:39 PM
dbikeman's Avatar
Yeah I didnt want to say for sure but I believe that adam is right and that the detroit wont work with the factory 4.88
Old 04-24-2005, 03:46 PM
jimbo74's Avatar
stock 4.88s and aftermarket 4.88s are differnt for some reason, and although a whole third will exchange, the parts are not interchangeable
Old 04-24-2005, 04:11 PM
airrikk17's Avatar
well that sucks . for some reason , aftermarket 4.88's are on back order and have been for a while , so i may be waiting a while until i get my 4runner back on the road , ill know more on monday when i can contact all the other suppliers of ring and pinions.
airrikk17
06-01-2021 01:51 PM
jerusry
10-19-2015 05:28 PM
andrewtexas123
07-14-2015 04:29 AM
MTLroadierunner
07-06-2015 12:17 PM
wilbertd
07-06-2015 07:39 AM
Quick Reply: will 4.88 stock gears from v-6 auto fit ....
