Will 2011 20" limited rims fit 2000 4runner?
Old 07-15-2011, 08:58 AM
michalik_piotr's Avatar
2011 Toyota 4Runner Limited 20" rims with new P245/60/20 Yokohama Geolanders, will they fit a 2000 4runner with no susp lift, only 1" bl.
Wondering about height? Width? In regards to rubbing and also the backspacing. Thanks....
Old 07-15-2011, 09:15 AM
waskillywabbit's Avatar
Is it even a 6 lug? Lots of new Toy stuff is 5 lug now.
:wabbit2:
Old 07-15-2011, 09:16 AM
Yes, 6!
Old 07-15-2011, 10:50 AM
scuba's Avatar
:wabbit2:
Only the newer tundras, sequoias, and land cruisers are 5 lug.
Tacomas and 4Runners are still 6 lug.
I hope it stays that way too.
Old 07-15-2011, 11:03 AM
My wife has a 11 4Runner but I don't even get to drive it, much less touch the tires.
She had a flat a couple weeks ago and got it fixed herself.
:wabbit2:
Old 07-15-2011, 11:19 AM
Gerdo's Avatar
That tire is ~31.6" tall and 9.6" wide. I don't know what the BS of the wheels are but if the BS is ~4.5" (+ or -), they should fit fine.
The big question is, WHY?
Bigger wheels/shorter tire sidewalls will ride rougher, release a bead easier when aired down, must be run at a higher pressure when wheeling, allow the rim to be damaged easier on obstacles, wont allow the tire to smear on obstacles as much.
Old 07-15-2011, 12:04 PM
Why?! Gerdo.... BLING, ofcourse, thats why! lol..... Yes, I am aware of all the things you mentioned and agree with you but I don't wheel.... I do a butt load of hwy miles, its a road/surf trip rig and about only off raod it sees is the beach. Currently running Les Schwabs 255/85 on LC rims and it all fits fine. Real reason why is that I need new tires b4 winter anyways and am looking at about $900 for the set I want (Revos). Anyways, after some thinking and wheeling/dealing this makes more sense. Plus, it might be kinda cool to roll on a set of OEM 20's? How wide are those rims/tires? 245 or 9.6" sounds skinny, no? My current 255/85 is already skinny. The LC's are 8". I wonder if the wheel/tire combo will be heavier?
Old 07-15-2011, 02:11 PM
J2F42C's Avatar
+1 on why. But everyone does their own thing.
If you do it, post some pics. Now that you can get a 2010 Limited for less than $30K, sell your 2000 for a down payment if $$$ is not tight.
Check the 5th gen T4R.org forum and I'll bet you will be able to find some of those rims for cheap.
Old 07-16-2011, 04:58 AM
KZN185W's Avatar
you'll need to wheel spacers to bring out the tires. iirc, these has got the +25 wheel offset
Old 07-16-2011, 12:49 PM
CYi5's Avatar
x2, they'll be sucked in.
06-01-2021 01:51 PM
mskalmus
05-28-2017 07:51 AM
icentropy
07-09-2015 02:12 PM
Cplmike
07-08-2015 08:47 PM
Jnkml
07-06-2015 01:20 PM
Quick Reply: Will 2011 20" limited rims fit 2000 4runner?
