will 07 Taco wheels fit on my 03 Taco
My friend just gave me a set of stock 07 Taco wheels from his Tacoma. He got custom wheels and said I could have his. I think they look better than the 03 wheels.
I was wondering if they have the same offset as my 03 stock wheels..I want to put my 285/75/16 Cooper STT's on them..Just want to make sure it will work first.
Anyone know about this..
Thanks, Andrew...
Thanks, Andrew...
They will physically fit, but the offset is different. It will look more "pushed in" unless you get some spacers. I'd stick with your current wheels, if I were you.
It'd be best to not run one but if you needed to I would just go with a quality brand (Marlin).
Fink
They are the TRD ones as pictured above..The thing is I am already using a spacer up front with my current wheels..I dont have any rubbing with the spacer now, so does this mean I might with the 07 TRD wheels..
Well I went down to the local tire shop and we measured the back spacing of both wheels.. The 07 TRD wheels have 1 inch less back spacing than my 03's.. So they will not fit with my current tires, hell they would probably rub with stock tires..So thats that..Thanks for all the input..
Are they 16's or 17's?
If you really want to make it work you need to find out exactly how much room you would need to make them fit.
Then call up Marlin and order you a set of their wheel spacers.
Fink
Since he was going to put on his 16" tires, I'm sure it was the TRD OR wheels he was talking about.
BeMiceElf
10-10-2015 09:40 PM
ripp96
07-25-2015 02:32 PM
