Wil 32x11.50 Tires fit?
Old 01-06-2005, 11:09 PM
MorphiasX's Avatar
Will 32x11.50 Tires fit?
Ok the deal is i only have enough money to buy either my tires or my lift. The fact is i need tires NOW, because im practically on racing slicks... The thing is i am planning on going with 4" suspension lift, but it is stock height right now. It has bald 31x10.50r15 kirkland AT's now, and i want to go with 32x11.50r15 BFG AT's, and eventually after the lift and regearing, 33x12.50r15. Anyways, my question is, will i be able to fit the 32x11.50's with no problems being that i have no lift? There is plenty of space in the wheel well with the tires i have now. Will i need to just perform the pinch weld mod? Whats the deal?
Here is a pic of the truck to kinda show the space in the well available:
Thanks...
Old 01-06-2005, 11:13 PM
jimbo74's Avatar
32x11.5s should fit... if you arent scared of doing the pinchweld mod, then i say you most likely will be fine...
Old 01-07-2005, 09:42 AM
deathrunner's Avatar
Maybe a little tbar crank. I've even seen guys do 33's. If you do 33x10.50 like me...you might be safe. A little tbar crank and a shackle or lift block in the rear(Cheap) and you should be able to fit 33's.
Flying91
45
04-11-2024 04:39 PM
BushPig
10-29-2022 06:26 AM
djpg2000
11-11-2020 04:56 AM
coffey50
07-28-2015 10:55 AM
Quick Reply: Wil 32x11.50 Tires fit?
