Wider fender flares
Old 07-01-2008, 02:55 PM
greyghost4x4's Avatar
Wider fender flares
Where could I get fender flares like these for my 99 SR5 4runner? When I move to WA I heard that it is against the law to not have your tire tread covered. I am going to put spacers behind my rims and I also have outlaw II rims which make them stick out a little more. Thanks.
Evan
Old 07-01-2008, 02:58 PM
Sorry I forgot to add the pic.
Evan
Old 07-01-2008, 03:12 PM
Whitey13's Avatar
The ones in the pic are Bushwacker, I believe.
Got a weimaraner?
4runnin2's Avatar
Get some bushwackers.
Or get some fiberglass ones from glassworks. About the only option for our 4runners.
Old 07-01-2008, 03:13 PM
galloway's Avatar
my friend has bushwackers on his and they work good
Old 07-01-2008, 03:20 PM
Got a weimaraner?
Yeah I have one and my wife has one. The little one weights 70lbs now and the bog one still sits at a solid 95. Both are great dogs.
Evan
Old 07-01-2008, 03:22 PM
Which ones are those from bushwacker? I love the look of those.
Evan
Old 07-01-2008, 05:01 PM
4runnin2's Avatar
They are the extended flare. Easy to install also.
Old 07-01-2008, 05:06 PM
crews462's Avatar
Maybe check the WA laws again. I'm from WA originally and I don't remember me and my friends having to worry about that.
Old 07-01-2008, 06:10 PM
24Runna's Avatar
http://junglefenderflares.com/catalo...x.php?cPath=24
I like 'em, but I don't think they make them for the 4Runner
I e-mailed them, have yet to get a response back.
Old 07-02-2008, 10:40 AM
Runner_Zuke's Avatar
RCW 46.37.500
Fenders or splash aprons. Fender Flares & Anti-Spray Devices
(1) Except as authorized under subsection (2) of this section, no person may operate any motor vehicle, trailer, or semitrailer that is not equipped with fenders, covers, flaps, or splash aprons adequate for minimizing the spray or splash of water or mud from the roadway to the rear of the vehicle. All such devices shall be as wide as the tires behind which they are mounted and extend downward at least to the center of the axle.
(2) A motor vehicle that is not less than forty years old or a street rod vehicle that is owned and operated primarily as a collector's item need not be equipped with fenders when the vehicle is used and driven during fair weather on well-maintained, hard-surfaced roads.
Fenders - Shall cover the entire tread width, at least 15 degrees to the front, and 75 degrees to the rear. Shall extend down to at least the center of the axle.
A $124 Infraction if you get pulled over for it!
Hope this helps...
Old 07-02-2008, 12:18 PM
That helps a lot. Thanks.
Evan
Old 07-02-2008, 12:42 PM
crews462's Avatar
I guess that settles that question? Thanks for the info and setting it straight zuke.
Old 07-02-2008, 09:24 PM
No problem! But no matter what the law says i still like the looks of the tires when they stick out from the body of the vehicle a bit and are not 100% covered up!
Zach_trun
01-22-2020 04:42 PM
live4soccer7
05-11-2016 06:52 PM
toyotasaurus
09-24-2015 03:30 PM
94toyy
12
09-14-2015 06:18 AM
justdifferentials
09-05-2015 06:52 PM
Quick Reply: Wider fender flares
