Sign in using an external account
| 95.5-2004 Tacomas & 96-2002 4Runners 4th gen pickups and 3rd gen 4Runners |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (0)
Wide Band O2 Sensor and Measurement
__________________
-Derrick |
#2 (permalink) |
Personal
Sales Rating: (0)
Yes, motor side of the cat. I've bee waiting for the 2.0 to come out. Looks like it is here.
__________________
FUN TOYS: '98 4X4 Taco S/C'd Fuel mods, WI almost done... '97 FZJ80 40th S/C'd Factory lockers CDL |
#3 (permalink) |
Personal
Sales Rating: (0)
Please forgive my ignorance on the subject, but what is so special about this unit? Why pay $650 for (from what I can gather) is just a monitor when you could get an A/F controller for $300 or so? ...or can the TE do what an S-AFC could do - and if so what kind of advantages does the TE have over it?
__________________
- Vince 2001 4Runner SR5 4WD V6, Sport/Highlander Edition Black · Optima Red-Top · Addco front bar · Sylvania Silverstars · Injen intake · 265/75 Bridgestone Deuller A/T Revo's Webshots (please ignore the terribly quality cell-phone pics) |
#4 (permalink) |
Personal
Sales Rating: (0)
[OP]
These are two different devices for different purposes.
The TE is purely a monitoring device (effectively a gauge) that leverages a newer oxygen sensor technology to see and measure a wider range of air/fuel ratios (i.e. wide band) than earlier technologies (narrow band) which aren't very effective at telling you how far away from "normal" you are, and typically just send a signal of "too high" or "too low". The TE device would normally be used as a piece of tuning hardware so you can do things like, run a little richer during peak boost with an S/C, etc. The S-AFC is a controller. It does not do any actual measurement of A/F ratios, but instead reads the Intake Manifold Pressure, Air Flow Capacity, Karmann Frequency, Engine RPM, Throttle Position, and Air Flow Correction %. It uses those characteristics to make changes to the MAP sensor signal to "fool" the ECU. With the S-AFC (or any piggyback that doesn't directly read the O2 sensor or is using an older style O2 sensor) you would still want some type of device to measure your actual A/F ratio to provide it with the right codes to offset the values going to the ECU. There are a couple of good diagrams on the TE site showing the characteristics of the newer wide band sensors which compare the signal and sensitivity of thresholds compared to the older narrow band sensors. http://techedge.com.au/vehicle/wbo2/wblambda.htm http://techedge.com.au/vehicle/wbo2/wbntk.htm Short answer is, one is a controller, the other is a measurement device. The wide band sensor gives you more data to be able to more precisely tune a piggyback or full engine management system for modifications. Hopefully I haven't misused any terms. Others please correct me if I have mispoken in any way.
__________________
-Derrick |
#5 (permalink) |
Personal
Sales Rating: (0)
So essentially, the S-AFC is in a matter of speaking, a cheap shortcut or a bandaid to adjusting the A/F ratio, while the TE gives you a much higher level of data to actually do the job right. Is that far off? Since the TE is only a sensor/data collection unit, what kind of tool would you use to finally adjust the ratio? SMT-6? Or is that just another "bandaid" since it alters the maps also? Thanks for bearing with me and my probably stupid questions - just trying to learn as much as possible since I've never seen this type of thing before!
__________________
#6 (permalink) |
Personal
Sales Rating: (0)
Has anyone thought about if the newer trucks and 4Runner's wide band O2 sensor would work on our older 96-98 4Runners?
Chris
__________________
http://www.utvrally.com |
#7 (permalink) |
Personal
Sales Rating: (0)
[OP]
Your questions are very fair, no worries. The TE is exactly as you described, a tool to measure the actual A/F ratios.
The S-AFC, SMT or FTC (which I am using) are required to make adjustments to the ECU (including timing, A/F mixtures, etc). It isn't a matter of one being better than the other. One measures, the other adjusts. Regardless of which products are used, you need both functions: tools to measure and tools to adjust. Expect to see piggyback units like the AFC, SMT, etc to keep getting smarter. There is no reason why they couldn't integrate the technologies so you could define things like the A/F mixture across various RPM, Manifold Pressures, etc and make the adjustments automatically. Hope this helps.
__________________
-Derrick |
#8 (permalink) |
Personal
Sales Rating: (0)
[OP]
Chris,
How did you dial in your larger injectors and SMT? Did you use a narrow band A/F sensor/gauge or did you go to a dyno? Thanks!
__________________
-Derrick |
#9 (permalink) |
Personal
Sales Rating: (0)
It's dialed in using my stock O2 sensor, the SMT-6 Software, and the BR-3 to check the short and long-term fuel trim. Supposably, I really need a wide band to properly tune it, but they sure are a lot of money, and I was thinking it could be a lot cheaper to pick a new truck (what years?) wide band from a junk yard for cheap if I knew they would work.
Chris
__________________
#10 (permalink) |
Personal
Sales Rating: (0)
Thanks Derrick, I think I've got a good handle on what's going on now.
__________________
#11 (permalink) |
Personal
Sales Rating: (0)
Derrick:
Some other wideband sensors are the FJO, Autronic (sorry no link), and MOTEC. I believe AEM has also released a wideband sensor, but I think it integrates with their EMS system and is not a standalone. All very nice systems but very expensive. Another option, if you are electronically competant is the DIY WB. I just built/tested one and it's pretty accurate compared to the Motec wideband at the dyno although the response time is a bit slower. Now I just need to build a display for it
#12 (permalink) |
Personal
Sales Rating: (0)
Chris:
The wideband o2 sensor doesn't necessarily have to work with the car for you to use it ... just weld it in and hook it directly up to a unit like the TechEdge, but leave your existing o2 sensor in place. I did that with an NTK wideband o2 sensor rather than worrying if it would work with the ECU or not. |
#13 (permalink) |
Personal
Sales Rating: (0)
Trangk,
I was hoping for a permanent unit by replacing the original O2 sensor with a wide band from one of the newer trucks. Who knows, but maybe someone has already tried it. Does anyone know what year the 4Runners and Tacomas went to a WB O2? Chris
__________________
#14 (permalink) |
Personal
Sales Rating: (0)
Chris-
I'm not sure if the newer O2 sensors are WB, but if they are they require a controller to understand the signal they produce and run the O2 sensor so it maintains a constant temp. It would require a lot of work figuring it out and I think that may be the reason a newer ESC hasn't been released for the new trucks. Derrick- I have an FJO and am very happy with it. I don't have any experience with the other brands or DIY ones so I can't compare them. If you get a DIY one make sure you buy the sensor first because there was a nationwide shortage of the sensors.
__________________
Milan _ _ _ _ _ __ _ _ _ _ _ _ Support our troops! '98 4R Limited '82 Toy 4.3, SM465, D20 <- Sold |
| Tags |
| band, characteristics, collection, data, description, narrow, o2, oxygen, program, sensor, start, toyota, wide, wideband, year |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 10in wide :vs: 8in. wide Pro/Cons??? | YotaBum | General Vehicle Related Topics (Non Year Related) | 14 | 11-22-2006 05:21 AM |
| 00 Tacoma O2 Sensor vs A/F Ratio Sensor | ir-rocks | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 04-11-2006 02:49 PM |
| O2 sensor code on 3.0 with new a sensor | rentedmule | 86-95 Trucks & 4Runners | 6 | 01-13-2006 09:53 AM |
| Wide Band O2 Sensor Mounting | derrick92130 | 95.5-2004 Tacomas & 96-2002 4Runners | 11 | 10-18-2003 04:49 PM |
| Narrow band vs wide band o2 sensor accuracy | Jeff B. in Michigan | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 09-01-2003 03:55 PM |
