Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Why are they rubbing?
Im currently running 265/75R16 on a 16x8 with a 4.5" backspacing. Whenever I turn full lock right, I hear this awful scraping noise...I cant seem to find where its rubbing...
Can someone point me towards where its rubbing and how I would resolve it? PS...this is the second season that the tires are used, except last season they were mounted on stock wheels, and no scraping then... |
| Sponsored Links |
#2 (permalink) |
With the 265/75/16's mounted on my 16x8 rims, the tires rubbed on the mudflap screws. A 2 inch lift fixed the problem...
Marc
__________________
'06 Tacoma Dbl-cab, 4X4, V6, 6-spd, SR5/TRD Off Road.... '90 4Runner 4X4 SR5 5-Spd '86 Shortbed 4X4 5-Spd, SAS'd ASAP '82 Supra 5-Spd Take your automatic and "Stick" it........ My Web Album in Progress |
#4 (permalink) |
I hate to say this...but.... is there some reason you can't just LOOK under there and SEE where they rub?....
__________________
All my Yotas are gone. Stuff to sell: http://www.yotatech.com/showthread.p...39#post1009839 -Phil |
#5 (permalink) |
They rub because something is located in the arc in which they need to travel.
I learned in Metaphysics that having two coexistent entities occupying the same place at the same time is not possible, so your report of rubbing confirms this. Sadly, there are only two resolutions. Either consult a Metaphysician so you can thrawt this law of nature, or apply a cutting utensil of your choice. |
#6 (permalink) |
[Sadly, there are only two resolutions.]
or smaller tires, or more lift, or don't turn so sharp... ![]()
__________________
#7 (permalink) |
or some nice fiberglass flares
__________________
1997 4Runner SR5, 4x4, Black, 3.4L, Automatic, Goodyear MTRs (305/70/R16), Revtek 3" spacers, Rockcrawler series 91s, Poweraid throttle body spacer, Optima red-top, Total Chaos 1" diff drop, Energy polyurethane steering bushings, Downey neoprene CV boots, No front swaybar, Sony CD, and a huge wish list . . . |
#8 (permalink) |
Well, like I said, I cant find where its rubbing...If only I know where its rubbing Id bust out the Dremel.
I cant afford, more like I dont want, smaller tires. I certainly cant afford the lift that I want. ANd I cant afford the FIberglass Flares, and my truck has OE flares... GRRRR...This is pissing me off...WHere does it usually rub? I dont have mudflaps...Is there a trick to finding the where the rub is??? |
#9 (permalink) |
Since the wit was wasted, here is a trick.
If it is rubbing enough to make a big noise, then there should be scuffs on the tire and on the truck. To help, you might try driving through mud and then seeing where the mud rubs off. If you park on flat ground, turn the wheel to full lock and then shut the truck off and get out, you can then imagine where the tire might go when it compresses and then look for scuffs. |
#10 (permalink) | |
Quote:
![]() Thanks for the chuckle. I've got rubbing too. I figured it out by stopping the vehicle WHILE IT WAS RUBBING and having a look under the truck. It's all rusty and greasy under there....yuk! ![]() I need to trim my fender/flare where it meets the door. It only rubs when I turn really sharp and backup -- so I try not to do that. ![]()
__________________
UZswap.com A site dedicated to sharing info for swapping the Toyota/ Lexus UZ (V8) engines into Toyota Trucks and 4Runners. My 4Runner 1993 4Runner, 1UZ (V8) auto dual ultimate crawler, double locked, 35's on beadlocked SR5 alloys, low lift, hacked fenders, tubbed firewall, custom armor TOOLandFAB.com A discussion forum dedicated to tools, fabrication & workshops. See my JD2 Bender Hydro Conversion |
#11 (permalink) | |
Quote:
__________________
Matt |
#12 (permalink) |
Have someone hold the wheel at full lock while you look. If you turn the wheel all the way and shut it down the wheels spring back a bit. Even so, you can eyeball what comes closest. Most likely is the fender liner over the pinch weld with that small a tire.
__________________
#13 (permalink) |
Is it your Tacoma or 4Runner. They are COMPLETELY different. It is impossible to run 315's with 2" susp and 1" body on a Tacoma. But I do on a 4Runner.
They are not the same vehicle and can not do the same things.
__________________
Steve Schaefer WWW.SonoranSteel.Com Suspension Lift Kits * Rock Sliders * Straight Axle Conversions * 4Runner/FJC Rubicon Express Lower Links * Accessories * Daystar Products Dealer * TJM Bull Bar Dealer * Deaver Leaf Spring Dealer * Tokico & Bilstein Shock Dealer * ViAir Dealer * Total Chaos Dealer * and like everyone else a Trail Gear Dealer |
#14 (permalink) |
Looks like a 4Runner with Limited flares. Not much you can do. Live with it until you get a lift.
__________________
#15 (permalink) |
Limited flares? Its most likely the flares... My 285s rub with a 2.5" lift, thats why I have a 4crawler box sitting right next to me. Too bad I don't see it being used til after finals
Just get a 1" body lift and you should be in the clear. RBs should be just over $100.C'mon man, peer pressure!! |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Rubbing on my shocks | ToyoRunner94 | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 08-23-2007 08:34 PM |
| rubbing | ken914runner | 86-95 Trucks & 4Runners | 14 | 02-06-2007 05:03 PM |
| A little rubbing | dantheman387200 | 86-95 Trucks & 4Runners | 16 | 11-05-2006 11:11 AM |
| rubbing but where? | TBob | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 02-22-2005 01:33 PM |
| rubbing issues? | Churnd | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 01-30-2003 10:44 AM |
