| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Why no writeup for cleaning MAF sensor?
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! |
#2 (permalink) |
Senior Member
FWIW...
I checked out my MAF when I cleaned out my throttle body. On my 96, it's just a very thin, delicate sensor that doesn't have much protection. I know how expensive these suckers are... so I ain't touching it. I cleaned the TB, but didn't do anything with the MAF. From the writeups I've read, on newer rigs they are easier to clean. Here's my writeup on cleaning the TB... it's got some MAF pics in it.
__________________
Jackson - My Site 96 SR5 4x4 - 33" MTs, open diffs, and 3.90s - LET'S ROCK! My runner has bee traded in *sniff* on an 06 SR5 long bed d-cab Tacoma. The tacoma is nice, but... *sniff* ... I'll update my site when I'm done grieving. Last edited by jacksonpt; 09-30-2003 at 06:49 AM. |
#3 (permalink) |
I think it is a very fine piece of wire, right?
You should be able to hit it with some kind of electrical contact cleaner without doing any damage. I am curious if anyone has done it on these vehicles and what was the best way to do it. Seems like a writeup would really help in this case (ie a don't clean 96-98 but do clean 99-02 and here's how you do it, type of thing) Can someone chime in if you have cleaned your MAF sensor on a 96-98 with a 3.4L
__________________
#4 (permalink) |
Its really quite simple...
a. remove maf b. clean c. reinstall maf ![]() Please feel free to copy this to the tech section: 99 4Runner 3.4 instructions for getting rid of P0171 and P0172 ECU codes: The MAF/IAT module is located just downstream of the air filter. Two phillips screws hold the module in place. You may need to move the cruise control servo box to get at the MAF/IAT. Once removed, clean by spraying contact cleaner on the IAT sensor (obvious little bulb thingy) and down into the MAF airflow tube. Looking into the downstream side of the MAF tube, you can see two wires which make up the hotwire MAF. The contact cleaner I used has silicone lube as part of the mix, so to get rid of that, just swish it around in dish soap and warm water, or use a toothbrush to get the gunk off. Don't be afraid of getting it wet, they are sealed. Let dry throughly. You can gently blow dry. Reinstall and watch the Check Engine light go off after 3 or 4 trips. Also notice that the momentary lag at 3200~3400 RPM is significantly reduced. The MAF/IAT module will stay cleaner longer by using a quality air filter. |
#5 (permalink) |
That's great Unhappy99!
Any pics you can post for us too? I would assume the 96-98 procedures are a bit different cause they use a different MAF. Anyone done it on one that looks like this? If so are the procedures the same?: ![]() Sorry Jackson, I borrowed your pic.
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! Last edited by MTL_4runner; 10-01-2003 at 03:59 AM. |
#6 (permalink) |
Yep
__________________
03 Dodge Ram 2500 CTD...its amazing Ex: 1999 4Runner JT3HN86R1X0199261...Now somebody elses Karl Malone Toyota 'Certified' POS Legendary Toyota quality is exactly that: A thing of legend. Defective fuel gauge - 'Certified' Defective brake rotors - 'Certified' Defective axle seals - 'Certified' Defective heater diverter - 'Certified' etc. etc. etc. |
#7 (permalink) |
And_a_2
__________________
#8 (permalink) |
And_a_3
__________________
#9 (permalink) |
And_a_4
__________________
#10 (permalink) |
Last one
__________________
#11 (permalink) |
What about the 3VZ-Es? I took mine out last week and there is just a "door" in the air passage. In the intake side, there is a little, yellow, plastic knob about 3/16" wide, 3/8" long that sticks down, too. Uncleanable MAF sensor on these engines?
__________________
1993 V6, 4x4, Xcab, 5 speed, Pewter Pearl. MagnaFlow cat-back 2.25", Diehard Platinum, Bilstein HDs, OME Steering Stabilizer, OME Rear Springs (One leaf removed), Air Horn, Century Cap, AR Outlaw rims, Michelin LTX M/S. Mobil1 5w30, Redline MT90 & 75w90. Alpine, JL Audio, MBQuart. |
#12 (permalink) |
If I understand you correctly, your MAF is a big spring-loaded butterfly valve (or door as you describe)? I had this on an 87 22-RE.
In this case, no, there is no cleaning of the MAF sensor. Vane type sensors do not need cleaning, only hotwire types do.
__________________
#13 (permalink) |
Thanks for posting those pics....this should help those with the 99 - 02 type!
Here they are so you don't need to view the attachments: Location of your MAF sensor: Removal of the sensor: Sensor out: Sensor parts: Hotwire location: Can someone post similar for the 96 - 98 type if they have them?
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! Last edited by MTL_4runner; 10-01-2003 at 03:58 AM. |
#14 (permalink) |
Guest
Mine is hanging out upside down for the time being without the box. After doing my body lift the factory air tube would not mount properly. I had to mount everything without bolting it down. I had to ditch the air box, rotate the MAG assembly over set the air cleaner on it and strap it down. Seems to work just the same. I am going to do Dr. Z's air tube mod asap though.
#15 (permalink) |
Are you guys cleaning it with Isoporyl(sp?) alcochol or electrical parts cleaner?
__________________
"POLICE STATION TOILET STOLEN ... Cops have nothing to go on." |
#16 (permalink) |
Just FYI guys, I don't think its as easy as just copying to the tech section.
Corey is the guy that uploads that stuff, and I believe he needs things to be in a certain format before submitting a write-up to him. Here's the guidelines. If you have time it would be nice if you could get them in this format so we could then add them! |
#17 (permalink) |
Why does that airbox have the GM logo on it????!!!!!
I hope it wasn't built by them. Nah.............it can't be...........its not broke yet.
__________________
1998 Tacoma SR5 4x4 Extended Cab K&N Filter, Deckplate mod......that's it until I get a raise! Just added...Bilstein shocks and TRD Springs....Still waiting for a raise! |
#18 (permalink) |
I remember someone else makes the tranny.....was it GM, Ford or Chrysler?
Anyone know the answer? I would love to do a writeup for the MAF but I don't have time right now. I might try to do one on an alarm install over X-Mas though.
__________________
#19 (permalink) | |
Quote:
__________________
#20 (permalink) |
Hi,
Anyone has pics for the '96 style MAF sensor for a 4Runner SR5 with the 5VZ0FE engine? Thanks in advance, El. |
#21 (permalink) |
I've used alcohol on mine a couple of times. I'll be switching from K&N to an Amsoil filter in the next couple weeks. With the K&N I have to clean the MAF every 2 months or so...and it always goes out at the worst time (usually while wheelin) which kills my TRACshun control and ABS...
Dozer
__________________
2009 Tacoma TRD Offroad |
#22 (permalink) |
Would you guys recomend doing this to even though I am not having any troubles with my MAF?
__________________
#23 (permalink) | |
Quote:
I would only clean if you are having trouble (ie CEL).
__________________
#24 (permalink) |
Thanks MTL, I have a 96 so I will heed your warning.
__________________
#25 (permalink) |
i go ridding alot, and my check engine light came on ,well after complete diagnostics i discoverd my MAF was clogged with dirt, i took it out and sprayed it real good with electrical contact cleaner, i put it back in and reset the computer(disconnect batt) and it never came on again, runs good to.
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Cleaning the MAF sensor | elnido | General Vehicle Related Topics (Non Year Related) | 2 | 04-12-2006 05:38 PM |
| MAF Sensor cleaning | Jeffires | Maintenance & Repair Archives | 8 | 08-16-2004 07:48 PM |
| Writeup- cleaning your fan unit | Bob_98SR5 | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 01-25-2004 11:45 AM |
| new writeup - throttle body cleaning | jacksonpt | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 06-16-2003 05:22 AM |
| Throttle Body Cleaning Writeup? | bbeast | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 12-26-2002 01:33 PM |
