Wheres the fuel filter
Old 01-14-2003, 05:40 PM
Mobbing94's Avatar
I have a 94 toyota xtra cab, 4wd and it has the 2.4 liter 22re. I need to replace my fuel filter and I cant find the thing anywhere. I was told it was on the frame rail, or firewall, then my buddy said he traced the line to the tank. I want to change it as soon as possible. thanks
Old 01-14-2003, 06:18 PM
Co-Founder/Administrator
Staff
Corey's Avatar
Hello, this should help you.
https://www.yotatech.com/forums/show...&threadid=4290
We have a pretty decent search feature here on the server, better than most other forums I have seen.
It works pretty good.
Old 01-14-2003, 11:13 PM
jx94148's Avatar
OK, I guess its right next to the oil filter from the pictures in that thread. Someone is using those nasty Fram filters with the cool grippy end that I copy with grip tape.
You can de-pressurize the line by disconnecting the plug on the fuel pump or removing a fuse on that circuit, I forget what its labled. Then start the motor. It will stall as it gets starved of fuel, the system is pretty much de-pressurized then.
On my roomate's Jeep there is a Schrader valve (just like on your tire valve stems) on the fuel rail to allow for easy de-pressurizing of the line. Maybe you have something similar. Just do it with the motor completely cool.
Old 01-15-2003, 01:44 PM
HALMAN's Avatar
On my 2nd gen. '93' Toyota, the damn filter is along the frame on the passneger side. A REAL PITA!!! I had to drop the tranny support bracket to get it out and install it, and there is NOT much room for ratcheting, had to wrench it an 1/8 of an inch at a time!:mad:
Definately made a diff when all was installed, gained about 2 mpg back.
Damn Toyota egineers.
Old 01-15-2003, 07:43 PM
Mobbing94's Avatar
I think on the 4runners it is on the frame rail but on the trucks with 22re's I think it is on the engine. Im going to go ask toyota where it is to be positive. Thanks for all your help.
K&n cool air induction kit, Jacobs offroad ignition system, 2 chamber flow master, High flow cat,
soon to have a downey 3 1-2 lift, header, trd super charger, 4:11 gears, 32 11-5 tires As the money comes in so do parts
Old 01-15-2003, 07:49 PM
Skydigger's Avatar
Did you have to de-pressurize the fuel system before replacing it? If not, was there tonnes of spillage? FSM says they don't need replacing but I'm hearing a lot of contrary opinions and would like to change mine; especially if it gets me better mileage.
Thanks,
Warren
Old 01-15-2003, 08:31 PM
keisur's Avatar
on a '99 2.7 liter it's on the engine under the ehuast manifold. smoke and mirrors might help in changing it. I had a hell of a time and my friends laughed at me when I told them it took me about 4 hours to do the job. they hadn't seen where it was obviously.
Old 01-16-2003, 06:55 AM
HALMAN's Avatar
No Skydigger I didn't have to depressureize the system. And not much spillage either, just have a tin can handy with some rags just in case. If you have the slotted box wrenches (metric of course) they will come in Real handy.
I was told the same about not having to replace the filter, but I checked around and the census was to go ahead and do it, it couldn't hurt. And it did get me 2 more mpg.
smthwsn357
12-04-2023 02:08 AM
Eggslinger
06-08-2019 03:32 PM
pyramid
07-30-2015 10:05 AM
ddg71
07-24-2015 01:24 PM
Fundy Rider
07-16-2015 01:35 AM
Quick Reply: Wheres the fuel filter
