Where to get longer U bolts?
Hi Everybody,
I bought myself some add-a-leafs to rid my 87' first gen 4Runner of its butt sag and I now I need longer U bolts. I was wondering if anyone knows the dimensions. I know that my springs are 2.5 inche's wide, so I assume the U bolts will be something like 2 5/8 inside width? I was able to measure the length of the bolt to the inside of the U and place it at about 5.5 inches. I don't however know what diameter the bolt is.
I talked to a place in my town that will make custom bolts but they want 63 bucks for 4!!! And I went to Napa and Shucks with out luck. Got any ideas who might have some?
Here's a recap of my questions:
Inside width of U bolt?
Is 6 inch U bolts long enough, or should I go for longer?
What diameter is the U bolt?
Where can I get them?
Thanks for your time, I know a couple of you guys have put on add-a-leafs too so your insite would be great!!
Erich
Erich
I went with the custom made u-bolts when I did the mod to my 85 pick up. I added 1" just to be sure, overall lenght 6.5" If i remember right they took a 7/8" socket this should give you the bolt dimension. The inside width is measured center to center. get under the rig a use a micrometer or a measuring tape, if you use a tape skip the first inch just don't forget the subtract it from your final measurement. If there is a tractor shop in your area, John Deere, they can usually find u-bolts to you specification with the strength you need. I think they are grade 8.
HTH
Nathan
HTH
Nathan
Just go to AutoZone. They are called "Suspension Performance" brand or something along those lines. They sell them alone, or with lift blocks. I have them on my truck and they work just fine.
