where is the fuel filter 99 4runner
Old 11-09-2008, 12:16 PM
swapped89's Avatar
My girlfriend has a 99 3.4 V6 4x4 5speed 4runner that needs the fuel filter changed. where is it? i have done mine before no problem. just wondering were hers is. and if i need to do any special fuel line bleeding or what not?
Input is very much appreciated. thanx
Old 11-09-2008, 12:21 PM
Elton's Avatar
drivers side near the frame rail towards the front cant miss it
Old 11-09-2008, 12:23 PM
Elton's Avatar
Old 11-09-2008, 12:46 PM
GSGALLANT's Avatar
No bleeding required. Remove old filter, install new filter, crank vehicle until it starts (it will take a few seconds longer to start than normal).
Old 11-09-2008, 02:54 PM
pfdaxe's Avatar
Be sure to release pressure by loosening gas cap prior to wrenching...
Old 12-26-2008, 08:39 AM
4Runner202020's Avatar
this is a somewhat old one but.... you dont need to pinch off the gas anywhere.. it seems as gas would leak out...
bobby
Old 12-26-2008, 09:23 AM
WEINERDOGBONE's Avatar
bobby
Some fuel does come out but only the amount in the lines in my experience. I replaced mine recently and cracked the front line bolt until it began to drip. I placed a pan under the filter and left it until it stopped dripping before removing the filter. This seemed to allow the pressure to bleed off slowly and prevented any mess.
Charecter1
11-06-2023 10:08 AM
icentropy
09-16-2020 02:47 PM
TURBOrunnerNM
07-22-2015 11:01 AM
redneck17
07-17-2015 07:44 PM
Gamble_STi
07-07-2015 07:54 PM
Quick Reply: where is the fuel filter 99 4runner
