wheel and tire question
Old 11-28-2008, 02:21 PM
sinister_rn61's Avatar
I tried searching but could not find an answer. I'm a newb to 3rd gen 4runners. I've got a 97 4runner limited 4x4 v6 automatic. Im looking at a set of pro comp steel wheels size 16x8 with 4inch backspacing. I'm going to run a 285/75/16 mud tire. I will be buying the sonoran steel 1.2 lift. am I going to have any problems running this combo? is the backspacing going to clear the a arms or should I get 3.75 backspacing. i would like the tires to stick out past the fenders a little for the agressive look, but dont want the tires to hit the fender flares during full compression. you guys running the 285/75/16 on the 3.4 auto, did you notice a big loss in power? I've got the tow package and 265/70/16 were stock so I'm only going from a 32inch tall to 33inch. thanks for the help.
Old 11-28-2008, 10:33 PM
Ohio4R's Avatar
Im pretty sure that setup will work with the 4 inch backspacing. You may have problems with rubbing at full lock depending on what tires your get.
I have 285's and an auto, you can tell a difference in power but its not that bad, for example on the highway the rpm's will be higher than with the 265's.
And the 265/70/16 is a 31" tire.
Old 11-29-2008, 03:10 AM
rocket's Avatar
If your set on getting the steel wheels, go with 3.75" BS. 4" works fine but wider is better. Hitting your flares will not be an issue.
See 'this' for pics & info regarding aluminum 4" backspaced wheels. Most are running 285's with the same amount of lift as the SS 1.2 and discontinued 1.1
You'd be going from a 31"~ to a 33" tire.
Old 11-29-2008, 04:28 AM
ok, thanks guys. Yea 31" tire. I actually have 265/75/16 now. Thats where the 32 came from.
Flying91
45
04-11-2024 04:39 PM
94whiterunner
9
09-22-2015 07:28 PM
DrZero
07-13-2015 09:59 AM
Yotoder865
07-09-2015 07:51 PM
Quick Reply: wheel and tire question
