wheel spacers
Old 03-10-2005, 12:36 PM
hiloracerboy84's Avatar
wheel spacers
whats the widest wheel spacers that are okay to use with stock lug nuts? ive heard of people using spacers over an inch thick...do you have to change your lugs or something or would they be okay with stock ones
Old 03-10-2005, 12:45 PM
Bigkahuna808's Avatar
Eh, go with adpaters over spacers. All pro-off road.com sells them. Spacers sometimes give you a front shimmy.
Old 03-10-2005, 01:08 PM
how do those work? you bolt the spacer up to your stock lugs, and bolt your wheels to the new lugs on the spacer?
Old 03-10-2005, 01:28 PM
4Crawler's Avatar
Spacers attach to the existing lug studs (up to 1/4" usually works for stock, longer studs needed for up to 3/4") and then adapters are available from about 1" on up. An adapter differs from a spacer in that is has 6 studs pressed into it that the wheel bolts to and 6 holes that bolt the spacer to the hub. So you end up with 12 lug nuts instead of 6 per wheel.
Here is a 1/4" spacer:
Here is a 1.5" wheel adapter:
Old 09-11-2005, 11:27 AM
Stegall984R's Avatar
Location: OmG, Hi2U !!! .... DANG, my chic's got some SEXY eyes.... among other things. WOOT WOOT !!
i just stacked like 15 washers on mine and slaped the wheels back on.. Its mad tyte dood.
Old 09-11-2005, 01:36 PM
PistonSlap's Avatar
I don't know if 'mad' is the best word to describe that.
Old 09-11-2005, 02:41 PM
Flamedx4's Avatar
Apparently the emoticon for tongue-in-cheek is invisible...
punks_is_4x4
08-21-2015 01:35 PM
coffey50
07-28-2015 10:55 AM
terminator
07-27-2015 07:13 PM
Yotoder865
07-09-2015 07:51 PM
Quick Reply: wheel spacers
