YotaTech Forums
Go Back   YotaTech Forums > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Sign in using an external account
Register Forgot Password?
Search
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 05-11-2004, 07:33 PM   #1 (permalink)
Personal Sales Rating: (0)
schlopecki's Avatar
What's wrong with my limiting straps?
Rear spring - OME 891
Rear shock - OME N86C
Limiting strap - 18" eye-to-eye mounted on the shock itself.
Strap has no free play and looks like it's limiting the shock even when
the truck stands on even ground - like there is no way for the axle to drop at all.
Here is how it looks - all wheels on the ground:
Click the image to open in full size.
What did I do wrong?
__________________
Sebastian
97 LX450
01 4Runner (FOR SALE - link):
285 Revos/16x7 OEM alu
4.56, r-ARB
OME882/N91SC, OME890/N86C, RB dif drop, Lars' discos, front-end-links-in-the-rear, SS bump stops and Panhard drop, InlandTrucks A-arms, MasterCraft limiting straps
ARB f-bumper, SS r-bumper, moded Carnage skids, moded RB RockSliderZ
1" RB BL, A/T cooler & filter, steering cooler, s-steel brake lines, AMSOil air filter, Mobil1 oils and filters, 12K e-MileMarker
schlopecki is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 05-11-2004, 07:45 PM   #2 (permalink)
Jonathan's Avatar
Send a message via AIM to Jonathan
Did you attach it to the top and the bottom of the shock? You shold use the mounting brackets that should have came with the kit and welded it in place right below the crossmember in the rear wheel well.
__________________
1996 Black 4Runner
V6 5 speed 4X4| Retrofitted E-Locker| SAW's| LC coils and Bilstein shocks| ATS A-arms | 285 BFGoodrich KMS2's| TJM T-15 With Warn M8000|Retrofitted Toyota Hood Scoop| Stubbs Sliders|Bushwacker Extend-A-Fender Flares| Extended rear diff breather| Uniden 510XL CB w/ 4 Ft. Firestik II Antenna|Dynomax Super Turbo Muffler|Black headlights and corners| More to come...
2008 Audi B7 Avant
Jonathan is offline
Old 05-11-2004, 07:53 PM   #3 (permalink)
Threadstarter [OP]
schlopecki's Avatar
Quote:
I ordered those straps independently from the suspension parts.
They mount to the top and the bottom of the shock.
I guess I choose the wrong length though.
I read some recommendations on this forum and I thought 18" was the right length.
Hmmm... maybe the recommendations were for the frame mounted top of the strap.
What should be the length for straps mounted to the top of the shock?
20"?
__________________
Sebastian
97 LX450
4.56, r-ARB
Old 05-11-2004, 07:57 PM   #4 (permalink)
Jonathan's Avatar
If you are using them to mount to the top and bottom of the shock you are probably going to need a much longer strap. I would send what you have back and get the Rancho 18" limiting straps that mount to the frame. They are much stronger and they are proven to work right.
__________________
1996 Black 4Runner
2008 Audi B7 Avant
Jonathan is offline
Old 05-11-2004, 08:44 PM   #5 (permalink)
pinnacle's Avatar
I would sugguest you cycle the suspension. At full droop measure the distance between the 2 mounting points of the limit strap. Just a general rule of thumb is that a limit strap streches about 1/2" for every foot in length. On mine for example was about 10.5" between the mounting points, so I got a 10" strap.
pinnacle is offline
Old 05-11-2004, 08:44 PM   #6 (permalink)
These are 18" limit straps;
BruceTS is offline
Old 05-11-2004, 08:45 PM   #7 (permalink)
This is the bottom, same tab as top, but welded to the side of the shock mount;
BruceTS is offline
Old 05-12-2004, 04:58 AM   #8 (permalink)
Threadstarter [OP]
schlopecki's Avatar
I guess I need to fabricate the top mount and weld it to the frame.
What's the distance from the frame to the hole in that top mount?
__________________
Sebastian
97 LX450
4.56, r-ARB
Old 05-14-2004, 05:52 PM   #9 (permalink)
Most any size tab will work, you just need to measure the distance between them before final welding. The bottom tab can easily be moved up or down to adjust the length.
BruceTS is offline
Old 05-14-2004, 09:11 PM   #10 (permalink)
sschaefer3's Avatar
Hello...........
http://fastq.com/~sschaefer/Downey.pdf
Spells it out pretty clear.
Also:
http://fastq.com/~sschaefer/recommend.html
States:
"Upper tab dimensions: The tab is 3/16" thick steel but you could use 1/4". It is 2 1/4" long and 1 1/2" wide. The hole is 1/2" and is 1 1/2" from one end and 3/4" from the other. The end that is closer to the hole is completely rounded, the other end is completely flat. Use the Downey instructions for the exact placement. The original pieces were actually made by Rancho and were part of a limiting strap kit. As seen in the Downey instructions the Rancho tab is sort of a boot shape. This tab does not require this shape and both sides can be straight."
__________________
Steve Schaefer
WWW.SonoranSteel.Com
Suspension Lift Kits * Rock Sliders * Straight Axle Conversions * 4Runner/FJC Rubicon Express Lower Links * Accessories * Daystar Products Dealer * TJM Bull Bar Dealer * Deaver Leaf Spring Dealer * Tokico & Bilstein Shock Dealer * ViAir Dealer * Total Chaos Dealer
sschaefer3 is offline
Old 05-15-2004, 06:23 AM   #11 (permalink)
Albuquerque Jim's Avatar
If you don't want to fabricate tabs look here Flat Tabs
__________________
'00 SR5, "Highlander"
Dual Cases, Aisin Hubs, E-Lock'd, Cryo'd, Chromo'd, ARB'd, 315's, Sonoran Steel Bumper, Lift & UCA's, 4 Crawl 1" BL, Armored...etc.
F-Toy #081 in progress
Dual Cases, 30 Splines, 5.71's, E-lockers, Hydro-Assist, 37's, DOM Hendrix Chassis, 80Proof, ORS, Sonoran Steel...etc.
Albuquerque Jim is offline
Old 05-17-2004, 09:53 AM   #12 (permalink)
Threadstarter [OP]
schlopecki's Avatar
Quote:
Originally Posted by sschaefer3
Hello...........
Also:
States:
I used specs from your website last week to fabricate those.
Thanks Steve for putting so much useful information on the website.
__________________
Sebastian
97 LX450
4.56, r-ARB
Yotatech
4WD Truck
Paid Advertisement
Tags
9000, choose, front, limit, limiting, mount, mounts, place, rancho, sale, shock, size, strap, straps, tacoma
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Limiting Straps as like swaybars? Tofer The Fab Shop 47 08-08-2007 09:21 PM
Limiting Straps Alstaz 95.5-2004 Tacomas & 96-2002 4Runners 13 03-02-2004 04:58 PM
Limiting straps in the front? cvlighthouse 95.5-2004 Tacomas & 96-2002 4Runners 8 08-08-2003 12:37 PM
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
