Whats the Worst that Could Happen
Old 10-23-2007, 01:52 PM
shyogy's Avatar
I was in a hurry when coming off a trail the other day and forgot to disengage 4wd (high) and proceeded to drive about 4 or 5 miles at 70 mph before i noticed and turned it off... what could happen if anything?
I've been noticing a rubbing sound when turning but i think that started before and i'm paranoid.
Old 10-23-2007, 01:54 PM
mikes19984x4's Avatar
sounds like you better start checking these things whenever you leave the trail, as that could definitely cause some damage if you would've kept on driving. but i just posted something on your other thread about the "rubbing" issue...
Old 10-23-2007, 02:35 PM
jimbob's Avatar
It shouldn't be any problem at all since it is an 02 with multimode --- unless you had the center diff locked.
Old 10-23-2007, 02:44 PM
eric-the-red's Avatar
Yup, with the 2001/02 you can drive forever in 4HI. All you did was burn a few extra ounces of gas.
Old 10-24-2007, 02:47 PM
Andrey's Avatar
as others have mentioned, you can drive all you want in 4WD HI, shouldn't be a problem at all. As a matter of fact, it is even recommended to drive 30-50 miles per month in 4WD so your gears will be properly lubricated.
83yotastockR
11
11-10-2015 06:54 AM
zombie_barbarossa
10-02-2015 10:54 PM
creecher10
09-30-2015 03:27 PM
beltcutter
09-30-2015 06:14 AM
mluz013
09-29-2015 05:53 PM
Quick Reply: Whats the Worst that Could Happen
