what year Pickup will bolt to 85 4runner frame?
i dont think any pick up cab will just bolt up to a 4runner frame, the rear most body mounts on the cab wont line up, so those brackets will need to be moved. im pretty sure anything up to about 90 or so can be made to fit since you already have to move the body mount brackets. but im not totally sure.
there is no direct bolt up, as runnerboy97 stated.... the second gen pickups (84-88) are the most similar to the ist gen runners... however the standard cab might fit with little to no modification, but the bed will msot likely need special mounts... they are based off the samedesign, but not identicale in that same aspect
6th Gear
19
12-10-2019 07:31 AM
crazypaint
06-23-2015 03:27 AM
