What wire for O2 sensor??
Dam,n heated o2.....what wire should i tap into for the AFM i got from autometer....
ive been under truck for about a hour trying to figure it out....im determining white or pink/grn.....i then went into glove box to see ecm and took off all the wire clips...i see a fatter wht wire....not same size as the one on the o2....is that the wrong one?
please let me know in detail...if picxs or write up avaliable that would be kickarse...im making write ups for everything i do soothers wont have to ask the same question....thanks!
Well for my 99 it was the White wire going into the ECU.
I guess you have the 4wire o2 sensors? 2 Blk 1 wht, and
1 Blu?
For the correct wire goto your Local Dealer and have them pull
up your ECU wiring diagram they can and you will be sure which
one and which pin.....Hope that helped
Peace Ron
1 Blu?
Peace Ron
i figured it out by shoving my digital multimeter in the white wire that went into ECU and started engine...the numbers began counting up and started fluctuating from .1->1v so that was it =]
thanks for your time!
If you do not already have it sorted, email me and ask me for the diagram you need and let me know what year truck, model and tranny you have.
Gadget@GadgetOnline.com
Gadget
www.GadgetOnline.com
Gadget
some drunk guy
08-03-2021 06:09 PM
zz_denis
09-06-2015 03:43 PM
